Price Check Information and pricing on old road grader
   / Information and pricing on old road grader #11
Yes the front wheels on a grader lean to off set the sideways pull of the moll board. Also to offset the crown of the road when traveling down/up it. I don't call myself a grader operator, but I have operated a grader from time to time.
   / Information and pricing on old road grader #12
"moll board"? = mold board?
   / Information and pricing on old road grader #13
If you want to take the time, shoot half a dozen pics from various angles. Then start a thread on the Heavy Equipment Forum website. Those guys will tell you all about your new grader!!!! Great bunch of people over there.
Here's a link to that website.
Motor Graders | Heavy Equipment Forums
In the past, I seriously considered buying a "Huber Maintainer", built throughout the 50's, and early 60's.
Never did find one close to home, at a price I liked though.
For those who might not know, a Huber looks like a stretched out farm tractor, with a belly blade.
A perfect machine for long driveway maintenance.
Much better than a box blade, land plane, or rear blade for driveway/road use.
   / Information and pricing on old road grader #14
Ovrszd:
Thanks for the pics, that is a cool old machine. Even cooler that you figured out how to run it. I used to follow the county guys around on my bicycle in the 60's watching them 'grade" the roads. I thought they had the best job ever.
Also thanks to the other gent that explained the front wheel tilt, I always wondered about that!
   / Information and pricing on old road grader #15
I can't imagine that you couldn't sell one, any day, any time, for more then scrap value.
I'm so jealous!
Maybe someone can explain, why grader wheels can go slanted as they do? Are they counter acting the sideways pulling effect of the mould board?Did you take delivery by helicopter?
Yes, it's to counteract side drag. Very effective.
The flexibility of the four wheel versions such as mine is incredible. The rear axle can be shifted from one side to the other. Uses for that can be seen in the picture I posted above of Danny running it. Allows him to place the rear wheels so they aren't running on the windrow of material coming off the blade.
The front axle also steers. This allows the dozer or tractor pulling the grader to stay in the middle of the road while the grader runs over against the shoulder. In extreme conditions the grader can steer into the drainage ditch area and clean it out while the pull machine stays up on the roadbed to not get stuck.
I wish Howard was still alive, he could better tell us the detailed uses of this machine. :)
   / Information and pricing on old road grader #16
Ovrszd:
You are welcome.
I run a new John Deere grader as a part time job, have been doing that for 27 years. I tutored Danny for a few minutes then started dragging him around. After an hour or so I quit driving where he needed to be, just drove down the middle of the roadway and made him figure out how to get where he needed to be as you can see in the pic.
The rear wheels lean on this machine as well. Without the use of tools the "table" can be pinned in 3 different positions for ditching or grading from either side. The moldboard can also be moved laterally on the table for ditch work. I think the last thing Howard had done with it was clean out a ditch. The table and moldboard were to the far right side of the machine and the right rear wheel was tracking straight behind the right front.
   / Information and pricing on old road grader #17
Here's a pic of a very slick ole Huber. Used to see them around here. But again, I think the Scrap Iron Monster ate em......
   / Information and pricing on old road grader #19
I'm not sure this one ever had any front wheels to start with...
It probably did have front wheels on it where your front pin is located. Around here those things never sell for less than $500, and some are listed for sale @ $900. I have a rear blade and a box blade, but they don't have the utility and finesse of a pony grader. Hang on to it!
What brand is yours?
EINGP PHT620 HAND PUSH ELECTRIC FORKLIFT (A57192)
EINGP PHT620 HAND...
2012 Ford Explorer Limited (A53317)
2012 Ford Explorer...
CRAFTSMAN 60 GALLON AIR COMPRESSOR (A57192)
CRAFTSMAN 60...
2018 Kawasaki Brute Force 300 ATV (A55853)
2018 Kawasaki...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
3' X 6' METAL SHOP TABLE (A57192)
3' X 6' METAL SHOP...
