Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%?
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%?
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #22
By now you all know that I know very little about bulbs/voltage/resistance. So this bulb could overwhelm the projector power supply? If it has a resistance rating of 14.4 ohms and the factory bulb has a resistance of 11.25 ohms, wouldn't it draw less current than the factory bulb?
Yes, but remember those dynamic effects I mentioned? Light bulbs are NOT fixed resistors. You are going to run a 12 volt bulb at nearly 3 times its rated voltage. It is going to draw some serious current, and it is going to be very bright for a short time. I don't think you are going to have a successful outcome with either of your scenarios. It will be interesting for you to report the results, and I have been wrong many times before, but in my opinion you need the correct bulb and I don't think any of your substitutions will be successful. I think your original substitution will just glow a bit and not be useful, and it would glow into the next century, and I think your next suggestion will glow very brightly for either a few seconds, or perhaps a few minutes. I don't know how your power supply is going to like the second substitution. It may be OK.
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #23
What is the bulb model?
Aaron Z
The bulb I need is a DLD.
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #26
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #27
I would think you could find at least a 24V bulb. And get a few for spares, they should take the 30V for a time.
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #28
They've made pretty big strides in LED color temperature lately. Incandescents are pretty inefficient, just look at the huge changes in flashlights over the last 5 years.
I have been happy with LED soft white bulbs. I moved all my LED daylight bulbs to the attic, crawlspace, garage, shop, etc.
yard machines tiller (A55973)
yard machines...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2018 Kawasaki Brute Force 300 ATV (A55853)
2018 Kawasaki...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
1999 CBar 20' Stock Trailer (A56469)
1999 CBar 20'...
