I had a snowy misadventure today
   / I had a snowy misadventure today #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
Watch the video.
What really happened is that I've been busting my butt trying to get as much material together into three slash piles to burn this winter all at once like I did last year.
The 14" snow we had was nothing but super wet, sticky hard to plow, and slippery. Nobody in their right mind is traveling anywhere and it had drifted over 2' high in many places. In my tractor I fell off the road once on my way over to my slash piles and got stuck in a ditch. I tipped my plow down and used it as a lever to slowly inch my way straight back up and out of the ditch.
I plowed out several neighbor driveways along the way.
And so it got dark, but I finally got to my new property and busied myself plowing access to my slash piles.
There is a bend in my main access road and last winter I thought, gee, wouldn't it be nice if I banked that corner a little so I wouldn't slide to the outside in the winter.
So this past summer, I did just that and put a slight bank into the corner.
Tonight while plowing, my plow caught that slight bank and followed it to the low point and I slid down to a tree that was caught itself between my front and rear wheels on the left side. I was unable to back my tractor up with trees behind it and unable to travel forward and to the right because I was stuck. Differential lock. Nope, stuck. Rocking back and forth. Nope, stuck.
Once I realized I really was stuck, several thoughts ran through may mind:
I left my chains at home 'cause I don't need them because I'm plowing. D'oh!
I don't have a key to get into my container to get out my 5-ton come-along and winch myself out because the keys are back home so I won't lose them in the snow. D'oh!
I may end up leaving my tractor and walking out. Double D'oh!
So while I freaked out a little, I hit on the idea of levering up the front of the tractor with my plow, while trying to get the plow to windrow to the right. My plow has a blow-off valve to protect itself from hits and wasn't super cooperative, but eventually I was able to windrow while holding the right brake, and trying to move forward and the entire tractor levered over to the right, away from the lousy tree, and then a hose on my plow blew because the blowoff valve was never meant to try to hold up the front end of 8400 pounds.
Without directional control, I was done.
On the way home, right where I had slid off the road there was a car and a truck stuck that had apparently been following in the trail I had made on my way out and I nearly got stuck there again driving around them.
When I got home, a neighbor told me on Facebook that two of our friends got stuck with their plow trucks tonight. I count myself lucky to have made it home.
   / I had a snowy misadventure today #2
Wow! It's really hard for us folks way way down here to even imagine that kind of snowy mess. :eek: I was sweating outside doing a few things this morning. :D
   / I had a snowy misadventure today #3
Thanks for the music and the tractoring for an early morning wakeup! It is raining here right now and temps dropping I need to change oil in generator and snow blower today.
   / I had a snowy misadventure today #4
Nice video! Getting stuck so far out could be more than an inconvenience. I recall burying my Farmall H in a blizzard 40 some years ago, but I was only about 1 mile out. It was still a long trudge home.
   / I had a snowy misadventure today #5
Thanks for the video. I have just had enough snow to last the season, but I would bet that I will see more, up close and personal next time. Ed
   / I had a snowy misadventure today #6
   / I had a snowy misadventure today #7
Man, I HATE heavy, wet snows. We've only had a dusting so far - otherwise cold rain. Glad to see YOU got home OK.
   / I had a snowy misadventure today #8
Love that last picture, everything looks so tranquil.
   / I had a snowy misadventure today #9
The first "still Pic" = the best of all reasons to have a cabbed tractor. There have been time when my driveway looks very much like that pic and I have to drive through with an open station tractor. That pic makes me shiver........
   / I had a snowy misadventure today #10
PLEASE be polite that keep that stuff there!!
I don't miss THAT kind of weather even one tiny bit!!
SR
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
Deere 325G (A57148)
Deere 325G (A57148)
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2013 CIMC REEFER TRAILER (A58018)
2013 CIMC REEFER...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52709)
2003 LEEBOY L150...
(2) SPRINKLERS & HI-RISE STANDS (A58374)
(2) SPRINKLERS &...
