Bad Day at Block Rock - errrr - Make it Bad Year.
   / Bad Day at Block Rock - errrr - Make it Bad Year. #721
Don't think so it does not even have a off on switch. Just looked at dials again with flash light. Not 1 of them says off.
How about a 1 / 0 switch? Gotta be something. Maybe temperature switch clicks off at the bottom?
Had another hard rain last night, it just didn't last long enough.
Tom you are correct, when the timer reaches zero it is suppose to shut off. it just didn't work cooking the pizza.
I'm really tired. Had gone to sleep and an elephant jumped on the bed. OK I don't have an Elephant around here. It was Bony & it
sure scared the crap out of. Well almost :D
All I post,
Just want t go sleep
Jim
Here is a picture of a tree that I wanted to braid. That didn't work. So I started weaving the branches in & out, forming loops, open spaces, & branches twisted twisted around the main trunk. It should be an interesting tree when it get a lot larger.
Pictures & I have been having problems ever since windows 10 took over.
Keep trying to call the bank &tv mfg, no luck, look at calendar & its still the week end. Dumb I guess ???
Rain yesterday was only 1/4 inch but even that was enough to run some water as the ground is so wet.
Go to web MD, Look up 2 things, liver spots & heat stroke. My tip is to wear a hat with a brim, Wally world has some cheap straw hats that will soak up water & stay wet for a while. Hope to find a portable mister. It sure helps. You may be able to find 1 at tractor world or similar.
I am sure happy with the old pistol, the more I look at it the better I like it. Rear site adjustable for wind age & horizontal, front site also adjustable for wind-age . Did paint front site red, helps ole eyes see it better. :D Have been to the gun range 3/4 miles in a straight line. Took Cody there a couple of times. But don't like to be around people with guns. Although it has been cool early in The AM the road ( sort of ) got the tractor stuck there so bad Had to go get Harvey & truck to pull it out.
More later if you stan stand it,
Jim
   / Bad Day at Block Rock - errrr - Make it Bad Year. #726
What I was talking about was a portable that you can carry with you.
Have them on back deck, due to lime in water they have to be replaced every year.
Ah ha... I got you. I also bought a cheap misting system and installed along the roof gutters on my deck in an L shape. Makes a nice little cool spot even in the afternoon sun. I ended up putting a simple inline filter in front of it to protect the tiny nozzles from clogging. Going on three years now without having a problem. The hose is plastic but the nozzles are brass and removable so they can be cleaned if necessary.
I'm on my way. :laughing:
Modern-day 'caveman' has lived in cavern for 40 years
   / Bad Day at Block Rock - errrr - Make it Bad Year. #728
"Problems with new TV it has started dropping channels, at first they didn't show up on the menu. Now it will not go to them at all."
Usually the TV is connected to the satellite box using video/sound connectors so that the TV doesn't control/select the channel or display the channel menus. That comes from the satellite decoder box. I have experienced loss of channels using Time Warner menus but not the satellite box. But when they were being "lost" it was because I had been using the decoder menus to just show "Sports" or "News" channel options and after that had trouble getting back to regular menu views and seeing all channels again. Try powering down the satellite box to see if that resets things.
hi Wata
OK may try that
FRUSTRATION I RECKON.
When things go wrong, they just just keep going wrong
Every time i get in a good mood something changes it. From little things to big ones.
Guess I should just stay in a bad mood.
Rip off co just ripped me off for another 48$$$. Call bank, yep they can reverse charges. All I have to do is go to bank about 50/60 miles away. They reverse charges & it dose not cost me anything & they give a temp card. Just got a new 1. PH went dead while talking to them $$ getting real low. 3 Weeks before $$$.
Some bills will go past due until I get new card. Even then I have call then with new ##. Rain has soaked TV box so it will not stay together in order for it to be mailed, Another 25 miles Could put in box for the other 1 going back.
Dog came home all wet & muddy. Bony came in & jumped on me, wide awake 2 hours sleep. Dod decided to gt in bed. never given a sign he even wanted too. Littlest thing lost my cool cup for beer.
More later. thanks for being my sounding board for my Peeing & moaning.
Jim
   / Bad Day at Block Rock - errrr - Make it Bad Year. #730
Did you hear about the guy who had surgery to connect his uretha and esophagus together? That way he could pee and moan at the same time. Bada boom, bada bing.
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
(3) Bicycles (A50860)
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
1997 EZ Spool Trailer (A49461)
1997 EZ Spool...
