Climate change: Is your opinion informed by science? Take our quiz!
Status
Not open for further replies.
   / Climate change: Is your opinion informed by science? Take our quiz! #51
   / Climate change: Is your opinion informed by science? Take our quiz! #52
   / Climate change: Is your opinion informed by science? Take our quiz! #53
Scored 65%. Thought I knew more about climate change. Need to put more time in my studies. My take on this is pretty simple. The atmosphere is a heat engine. Add more heat (=energy) to that engine the processes that that engine can perform are going to have more energy available. So expect to see record high temperatures, record winter snow storms, stronger wind storms (hurricanes, tornados), faster melting ice, permafrost melting, faster rising sea levels, etc. The debate is over. Anthropogenic CO2 is causing this increase in available heat energy that drives atmospheric processes.
Your problem is none of those things have happened! Just one example.
Season Approaches: U.S. Hits Record 127 Months Since Major Hurricane Strike
HS
   / Climate change: Is your opinion informed by science? Take our quiz! #54
Did you know tree rings of trees in the west that go back 8000-10000 years show droughts of 200 years are common in that area? It would be very normal if lake mead dried up for 50 years. HS
It will, just a few more years.
   / Climate change: Is your opinion informed by science? Take our quiz! #57
Good one, Santa might have to relocate, swap his sleigh in for yacht or call off Christmas.
CALL OFF CHRISTMAS????? SAY IT ISN'T SO!!!!!!! :eek:
   / Climate change: Is your opinion informed by science? Take our quiz! #58
Fished Devils Lake in ND a few years ago. It's a lake that seems to just keep growing...often cited as a sign of climate change I guess. Then I heard that people have found fish fossils 25 miles from the existing lake boundary (meaning we've been there before)...
   / Climate change: Is your opinion informed by science? Take our quiz! #59
There's nothing normal about lake Mead... its a reservoir.
   / Climate change: Is your opinion informed by science? Take our quiz! #60
The inference was that lake Meade level going down is proof of man caused global warm. It's not! HS
Status
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Toro Z Master Mower (A50324)
Toro Z Master...
