hunt4570
Elite Member
- Joined
- Feb 10, 2015
- Messages
- 4,058
- Location
- South Carolina
- Tractor
- Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
Ok, Kubota 3540W LA724 loader, owned it about 6 months. 450 hrs
Look at the pics cause my terminology is most likely wrong
. You will see the pivot pin working its way out of the hole, this is the second time I've had to replace the bolt holding it in. Granted I replaced it with probably a grade 2 bolt I had in the garage, now my question..
Should I replace it with a grade 2 (shear bolt) or go with a grade 8? Do I really need it to shear at this spot? I'm thinking not. Also... is there some underlying problem going on here I need to attend to? I'm the second owner of this tractor and it only has about 450 hrs on it
And yes I grease those.
Thanks.
Thanks.
