buzlloyd
My usually trusty JD 4400 will not start. Before this problem, the tractor was running well with no apparent issues. Turning the key sometimes produces a loud click but more frequently does nothing. I have replaced the battery although with an Autocraft battery which has a 450CCA rating rather than 500CCA which is the JD spec. (an asst. mgr. at Carquest stated that this battery would be adequate although its life might be not as long as for a battery with the 500CCA spec.) No change. With the key removed, my meter reads 12V at the positive starter terminal which is not what I expected. My operator's manual does not seem to have an electrical schematic diagram. I would appreciate any and all insight that will help me get her running again.
