s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,548
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
We used real stone veneer but same basic installation method. In between switching masons I decided to give it a try. After only about 20 square feet I quickly decided to leave it to the pros. I would still be working on it.
The part I would have a hard time with, mentally, is mixing up the stone shapes and colors (if it's that type) to get it looking right. I'd be worried about having a bunch of gray rectangles grouped together, for instance. However our masons did it, all their stone work came out looking great. I think there were 4 shades of stone and about 10 different shapes to juggle, not counting 3-4 different corner styles in the 4 shades. They got it together in a random but unified pattern.
I will say this, sticking the stone veneer on looks pretty easy but I imagine you need the right touch with the mortar mix. We had a few stones get knocked off during construction when the electricians were drilling/cutting to mount fixtures, and those I stuck back on with construction adhesive (worked fantastic). Makes me think you could do the whole thing that way if it was a "dry stack" style without any mortar or grout between stones. If I ever do driveway columns to match our home, I figured I'd build the column with concrete block, then glue on the veneer with construction adhesive.
