CK35 HST shattered piston at 400 hours
   / CK35 HST shattered piston at 400 hours #11
Call Kioti customer service and see what they suggest doing.
Mention the potential missing ring which cannot be verified until the piston is removed.
   / CK35 HST shattered piston at 400 hours #12
I'd really like to see a happy ending here. Good luck with contacting Kioti. I hope they stand behind their product.
   / CK35 HST shattered piston at 400 hours #13
Have you called and got any prices on a replacement? I would call someplace that does some volume and is well known for the Kioti tractor like Error
Sorry to hear about this and I know selling it will be at a loss.
...I would be tempted to blame it on misuse by the neighbor, but in all honesty ...
I really appreciate that, thanks. Initially I had thought, this has to be his fault, that he over-worked the engine while grading our road and moving around buckets of gravel. However, I've since been told that these engines can't be over-revved because they have built-in governors... is that true? Also, during the time that he had the tractor, he would work for about an hour in the morning and then go home and take a break to cool off from the sun, and then do the same in the afternoon, and then put in another hour or so near sundown. It wasn't like he was on it all day, every day. He can't take that kind of heat (few of us can down here). So yes, my gut reaction was that he over-worked it, but then I thought, how could that be? And now based on the input from you folks, it sure seems to make more sense that the cause was most likely a manufacturing defect.
I'm not a confrontational guy, and my neighbor is indeed a good neighbor. I harbored ill thoughts about this situation, but haven't actually said anything to him about it. He knows the tractor has a serious issue that happened while he was in the seat, and he doesn't feel good about it. To me it would be a relief to know for sure that it's a defect and not mis-use.
Call Kioti and see what they suggest doing.
I wouldn't begin to know how to do that. There's no "customer service" option on their web site. I can imagine that they'd want me to go through my dealer. I tried that, and my dealer was way too busy with other work to even look at it.
   / CK35 HST shattered piston at 400 hours #16
CenTex Chris;4203084 My neighbor had borrowed my tractor to spread several truck loads of gravel on our private road. It's a 2010 Kioti CK35 HST with 408 hours said:
PS By the sounds of this description it sounds as if this person wasn't smart enough to shut the machine down when it showed signs of something wrong. That being said I wouldn't let him borrow anything else ! Think about it "I smelled something hot" They keep running it and next thing you know you need a head replacement because they overheated it. Common sense approach to any ones machine is if it starts acting funny you shut it down right then and there and call the owner, not continue to work or drive it back for them. Any damage done will only get worse with more run time !
   / CK35 HST shattered piston at 400 hours #17
I don't know why the link I posted comes up as an error but it does take me to MIE
I just put in an online service quote request to the next-closest Kioti dealer from mine. Basically I asked them for a parts & labor estimate for engine rebuild or replacement, whichever is less. It should be a standard line item on a rate card, so I'm hoping they'll be able to provide that info without having to drag the tractor all the way down there. Now this outfit is a "Kioti 5-Paw" dealership, supposedly that makes them better than average, so I'm keeping my fingers crossed that they'll respond. Funny thing is, as the crow flies, they're only a few miles further away than my dealer. But, they're on the opposite side of San Antonio from me which makes them a lot harder to get to.
   / CK35 HST shattered piston at 400 hours #19
That pretty much true.
But going down a steep high with the throttle open the weight of the machine can overrun the governor
   / CK35 HST shattered piston at 400 hours #20
Be nice, tell Kioti the problem, that you're out of warrantee, but you've have a piston fail from un unknown defect or a potential missing ring that led to the piston failure, and whatever the case may be, the cause of the problem cannot be verified until the piston is removed and inspected by a service technician. If Kioti offers nothing, then offer suggestions to Kioti that would make you happy and see what their reaction to your pleas are. Ask also, given your location, where to go or if you should you continue working with the self-employed Kioti certified technician that diagnoses the problem.
I bet Kioti offers helpful direction and may even step in partially or wholly to sort out your problem and make you a happy camper.
Contact Us
Whatever assistance you need, KIOTI is here to help. Simply click on the appropriate option below or give us a call.
CONTACT INFORMATION
KIOTI Tractor Division
DAEDONG -USA, INC
6300 KIOTI Drive
Wendell, NC 27591
Phone: 1-877-go-kioti
Fax: 919-374-5001
Operation Hours: 8:00am – 5:00pm EST (Mon. – Fri.)
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
