Comparison Kioti NX5010 vs Kubota L4701
   / Kioti NX5010 vs Kubota L4701
I found a decent deal on a DK40SE HST with loader and backhoe - going to check it out. If it is in decent shape, that just might take the cake. Not as much power as the NX5010 but it is half the price. Sometimes money talks!
   / Kioti NX5010 vs Kubota L4701 #12
If it is similar to when I was comparing the DK to the Lnn00 series the Kubota units do not come with standard quick attach on the loader. Perhaps that has changed now.
   / Kioti NX5010 vs Kubota L4701 #13
The DK40SE will have all the goodies on it like the extendable lower lift arms, the 3 point hitch adjustment lever in the back, cruise control, 1 set of rear hydraulic remotes standard, etc. It's a really good tractor if it meets your needs.
   / Kioti NX5010 vs Kubota L4701 #14
Ditto, these are good tractors without all of the tier 4 BS, don't buy a wreck buy a like new one:thumbsup:
   / Kioti NX5010 vs Kubota L4701 #15
Nope, not changed...SSQA would be standard on a DK series, but extra on an L series
   / Kioti NX5010 vs Kubota L4701 #16
Must be your kioti price book comparison for Kubota is different then what Kubota prints. Quick attach bucket is standard on a 765 loader.
Accurate facts are all that should be posted here.
   / Kioti NX5010 vs Kubota L4701 #17
By golly you are right, it is on the 765, not the 525 though. Sorry..
   / Kioti NX5010 vs Kubota L4701 #18
This thread is the most ruthless demolition of the basic L series versus Kioti I have ever seen. All absolutely correct. The L can't stand up to the Kioti CK, DK, or NX series, which it equals in price. That's the reason I have a Kioti. To equal Kioti, you need the GL, which a lot more money.
To the OP, the DK40 is a great tractor, but something concerns me here. You started with a 50HP tractor, and now are looking at a 40HP tractor. Money talks, but if you need that 10HP, you will likely regret it later. If you don't need that 10HP, why did you start at 50?
Also, I think you said the tractors were at 33K. If that's an open station, it's high by several thousand for the going price. Closer to 30 is more like it.
   / Kioti NX5010 vs Kubota L4701 #19
Let's talk about price: I have been quoted $35,224 for the Kioti and $35,000 for the Kubota.
Thoughts?
Go for the Kub, think of all the implements you could get with the $224
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A55852)
2001 Pierce...
12ft X 16ft Storage Shed (A55853)
12ft X 16ft...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
