What Do I have?
   / What Do I have?
Deere made industrial versions of the 1010 and 2010. Some were only loader tractors and some had backhoes. The cast iron nose was standard equipment for the industrial versions. They had heavier front axles as well. Also made crawler versions.
Ok I believe your correct. I found a casting number on the engine block T17513T. So now im thinking its a 2010?
   / What Do I have? #12
Take heed of any answers and advice you get from jd110, you won't get better or more knowledgeable advice any where else on this forum.
   / What Do I have? #13
T17513T was used on both 2010 and 1010 later serial numbers. This is according to parts catalog. I will check technical manual to verify.
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
2025 LandHonor LHR-GAC40Y 2-Stage Air Compressor (A50860)
2025 LandHonor...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2020 Bell B30E Off Road Dump Truck (A50860)
2020 Bell B30E Off...
