Dakota MURS driveway alarm modifications?
   / Dakota MURS driveway alarm modifications? #1
RobA
Chester County, SE PA
Kubota L5030 HST
I recently purchased the Dakota MURS driveway alarm with the buried probe. There is a relay in the back of the base unit to attach a bell or siren. Has anyone used this relay to trip lights? I want my barn lights to come on when the driveway probe detects a vehicle which would be several hundred feet before motion detector lights would come on.
   / Dakota MURS driveway alarm modifications? #2
Call Dakota's tech support and they will probably point you in the right direction. I talked to them 2 days ago before buying another motion detector for my driveway. Super helpful folks.
Thanks. I'll probably be calling them sooner rather than later. I didn't have a chance to bury the probe yet - just ran it over with the mower and cut the wire! :duh:
   / Dakota MURS driveway alarm modifications? #4
I talked to them briefly about the driveway probe. I think that he mentioned that the cable could be unplugged, but that might just be from the transmitter and not the probe itself. He did mention that it was a good idea to put the cable inside a piece of 1.5" conduit in order to protect it once you decided where you wanted it. :)
   / Dakota MURS driveway alarm modifications? #5
Do you have the M538-BS base? It has two simple spring-latch connectors on the back to control external lights/buzzers. The contacts are normally open, rated for 5A at 28VDC according to the Dakota Manual.
http://dakotaalert.com/manuals/M538BS.pdf
For 120VAC lighting, I assume you would want to use the base unit relay to control a second higher-amperage relay for the 120VAC.
I ran my probe wiring in cheap 1/2" PVC conduit and then rigged up several adapters to increase it up to 1-1/2" for the probe itself. Buried it all just a few inches deep. Works perfect. It DID false alarm with the as-delivered sensitivity setting whenever there was heavy rain or nearby lightning. I find that a setting at about 11 o'clock to 12 o'clock is about right.
- Jay
I talked to Dakota. I may use their light timer which plugs into the back of the base unit. It can handle up to 250 watts. I'm thinking of wiring a spotlight with a plug in cord instead of hard-wiring it, to take advantage of their timer/relay which accepts a plug.
   / Dakota MURS driveway alarm modifications? #7
It would be nice if you could interface this to a Z wave or Zigbee format control system. Ten years ago, I would have suggest an X-10 transmitter that has a contact closure input, but this new stuff has replaced that and as yet I have no experience with it. I am waiting for prices to come down..
I have some Insteon stuff in the house. It works well. Easy too. But I can't figure out how to interface the 2.
18in X 36in Bucket (A48083)
18in X 36in Bucket...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
UNUSED Steel Diamond Plate (A50860)
UNUSED Steel...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
Char-Griller BBQ PIT (A50860)
Char-Griller BBQ...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
