Dakota MURS driveway alarm modifications?
   / Dakota MURS driveway alarm modifications? #1
RobA
Chester County, SE PA
Kubota L5030 HST
I recently purchased the Dakota MURS driveway alarm with the buried probe. There is a relay in the back of the base unit to attach a bell or siren. Has anyone used this relay to trip lights? I want my barn lights to come on when the driveway probe detects a vehicle which would be several hundred feet before motion detector lights would come on.
   / Dakota MURS driveway alarm modifications? #2
Call Dakota's tech support and they will probably point you in the right direction. I talked to them 2 days ago before buying another motion detector for my driveway. Super helpful folks.
Thanks. I'll probably be calling them sooner rather than later. I didn't have a chance to bury the probe yet - just ran it over with the mower and cut the wire! :duh:
   / Dakota MURS driveway alarm modifications? #4
I talked to them briefly about the driveway probe. I think that he mentioned that the cable could be unplugged, but that might just be from the transmitter and not the probe itself. He did mention that it was a good idea to put the cable inside a piece of 1.5" conduit in order to protect it once you decided where you wanted it. :)
   / Dakota MURS driveway alarm modifications? #5
Do you have the M538-BS base? It has two simple spring-latch connectors on the back to control external lights/buzzers. The contacts are normally open, rated for 5A at 28VDC according to the Dakota Manual.
http://dakotaalert.com/manuals/M538BS.pdf
For 120VAC lighting, I assume you would want to use the base unit relay to control a second higher-amperage relay for the 120VAC.
I ran my probe wiring in cheap 1/2" PVC conduit and then rigged up several adapters to increase it up to 1-1/2" for the probe itself. Buried it all just a few inches deep. Works perfect. It DID false alarm with the as-delivered sensitivity setting whenever there was heavy rain or nearby lightning. I find that a setting at about 11 o'clock to 12 o'clock is about right.
- Jay
I talked to Dakota. I may use their light timer which plugs into the back of the base unit. It can handle up to 250 watts. I'm thinking of wiring a spotlight with a plug in cord instead of hard-wiring it, to take advantage of their timer/relay which accepts a plug.
   / Dakota MURS driveway alarm modifications? #7
It would be nice if you could interface this to a Z wave or Zigbee format control system. Ten years ago, I would have suggest an X-10 transmitter that has a contact closure input, but this new stuff has replaced that and as yet I have no experience with it. I am waiting for prices to come down..
I have some Insteon stuff in the house. It works well. Easy too. But I can't figure out how to interface the 2.
2001 International 3800 4X2 School Bus (A50860)
2001 International...
UNUSED Grey Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Grey...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
377811 (A48836)
377811 (A48836)
2018 Chevrolet Tahoe SUV (A48082)
2018 Chevrolet...
1996 Mack RD688S Cab and Chassis (A50860)
1996 Mack RD688S...
