I hate grease guns
   / I hate grease guns #41
All I have to say is that I greased the loader again today, and it takes far longer to clean the grease Zerks prior to greasing than it does to grease the Zerks with my Lock N Lube coupler. The thing just takes the "hassle" out of greasing. I know I sound like I have a stake in the company.. I wish. They dang things is expensive. But it works. And you can't say that about every high priced thing you buy.
It's a game changer!
   / I hate grease guns #42
I have been persuaded to go ahead & order a Lock and Lube!!! I hope I have as much luck as everyone else has!!
   / I hate grease guns #43
Looking at the lock and lube, it falls short in the useability standpoint when compared to the superior Univerco IMHO. The big advantage to the univerco is that it is exactly the same size as a conventional coupler, no large levers or springs to get in the way. Case in point I can get the Univerco into the Ujoint fittings on the driveshafts of a BX or ZD and I doubt the lnl would fit. Its lesser known than LnL but so far it seems to be superior in my usage.
Plus its readily available from any Napa or Deere dealer in Canada, which means no shipping and easy to find or get warranty.
   / I hate grease guns #45
I missed something, what do these 30 something dollar couplers do that this one won't?
https://www.google.com/shopping/pro...uzmWKg&ved=0CB4Qpis&ei=nOlsVfPwM4u2sAWo44OADQ
Or these, up to 10,000 Lb pressure.
Milwaukee Grease Gun Couplers ? 2 PK PK 49 16 2649 | eBay
Other than staying on when you want them to.
Coming off only when you want them to.
Not need to be held on the fitting entire time you are running the grease gun.
Not leaking out the sides of the coupler the entire time.
Help make greasing suck a little bit less.
Other than that. Nothing.
   / I hate grease guns #46
And not leaking out the sides of the coupler the entire time. Nothing.
Exactly.
Does anybody have a tire chuck they recommend that stays put as well? I've got some el cheapo locking one that is a joke.
   / I hate grease guns #47
I got a locknlube about a year ago and it is a great addition to a grease gun. Seems that the old style couplers get loose after several times of usage, maybe the spring thing on the end gets "sprung" and won't hold tight any more. The locknlube goes right on and stays there until I release it! Worth every penny! :thumbsup:
   / I hate grease guns #49
I must be doing something wrong, mine leaked so I took it off.
Send it back Don and get a new one. This is truly a time and mess saver.
   / I hate grease guns #50
My LnL continues to perform flawlessly and brings a smile to me face each time.
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
Bolens G272 Tractor (A50860)
Bolens G272...
2025 LandHonor LHR-GAC40Y 2-Stage Air Compressor (A50860)
2025 LandHonor...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
