Mahindra 3215 starts but dies after a few seconds
   / Mahindra 3215 starts but dies after a few seconds #1
JRsbone
Warsaw, MO
Mahindra 3215
I have a Mahindra 3215 gear drive that will start then runs for a few seconds then dies. Fuel filter and eveything looks good. I was wondering if anybody had any ideas of what could be causing it to die?
   / Mahindra 3215 starts but dies after a few seconds #2
Have you checked the fuel shut off solenoid fuse and solenoid?
After a little checking I think it is the solenoid, but I am having problems finding a replacement part. The only part, after looking at the parts diagrams, that I can find that even comes close to resembling the solenoid is called the pump assembly, fuel. Would that be the solenoid? I have checked several different parts sites and that is all I can find. Nothing that says solenoid.
   / Mahindra 3215 starts but dies after a few seconds #4
fuel filter may look good but could still be partially plugged. Also check your fuses. Start with the easy things first.
I have checked the fuel filter and the fuses, I was hoping that it was one of them so it would be an easy fix. But no such luck, they all look good.
   / Mahindra 3215 starts but dies after a few seconds #6
Check your fuel lines for a piece of debris acting like a check valve. Back blow them with compressed air.
   / Mahindra 3215 starts but dies after a few seconds #7
Also, your operator's manual has a recommended number or hours at which you are supposed to drain your fuel tank for debris removal. I went nine years before doing mine, with never a problem. However, you should drain yours when you hit the number of hours, or just for good measure.
Thanks for the suggestions, I will give them a try. The tractor is actually at my parents house, dad borrowed it, so I haven't been able to work on it just had him try some things. I am heading out there today and will give the suggestions a try.
   / Mahindra 3215 starts but dies after a few seconds #9
Usually, (I understand) if you give them the key to the equipment/vehicle, they are responsible for it....BobG in VA
Hey folks, Sorry, I meant to put this under the "STOLEN" heading....My Bad... BobG
I did find one fuse blown but tractor is still acting the same. Does anybody know where the shutoff solenoid and shutoff solenoid fuse are located?
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
71068 (A49346)
71068 (A49346)
