Is the F3680 still a current model?
   / Is the F3680 still a current model? #21
Were you in low range or high? Fluid warmed up enough?
RPM range (WOT?) or slower.
I also use ear plugs , have slight hearing loss from various weapons I have been around/trained on.
Am not as old as J.T. but could draw early SS
Enjoy,
It wasn't warmed up yet, low range, medium rpm. I didn't have the mower engaged since I wasn't mowing. I'm just comparing it to my tractor, where I don't really hear any HST noise under any conditions. I'm sure it must be normal, I'm just not used to it. I'm sure The mower noise should drown out any HST whine. Thanks for the replies!
   / Is the F3680 still a current model? #23
I picked my F3080 with 72" RD deck up today from Messick's. My yard is currently very wet, so I backed it off the trailer, did a few figure 8's in the driveway, and parked it in the garage. One thing I noticed is the HST seems to have a loud "whine," which I hope will quiet down with use. The HST trans on my L5740 is very quiet, so maybe I'm just not used to it. Is this normal, and will it ever quiet down as it breaks in? I'm not sure what HST fluid is used as factory fill, but I plan to use the super udt at the 50 hr break in service. I still have lots of snow that needs to melt away, but I can't wait for the grass to start growing!
I had the "whine" on my GR2120, took it back and had them check it out. Was told that the RPM is set higher then the manual calls for causing the whine, and turned it down to 3k-RPM. Whine gone! Maybe something to check out on your F-series.....
   / Is the F3680 still a current model? #24
Did my first mowing of 2015 today. 20 seconds of glow plug, just turned key for a second and fired up like it had just been turned off 5 minutes before. :dance1:
   / Is the F3680 still a current model? #25
Argggg....you guys giving me F series fever again. I'd like that one with the expensive deck....so I can trim around ponds, without getting stuck.
   / Is the F3680 still a current model? #26
Your dreams CAN come true.........just a phone call away.:D:cool2::welcome:
   / Is the F3680 still a current model? #27
Just bought a '14 3680 w/ a 72" deck, a new 52" blower and new cab. Can't wait for it to snow !! unnamed (13).jpg
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
JCB 3CX 15HFCE BACKHOE (A51242)
JCB 3CX 15HFCE...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
