Best Landscape Rake for the money?
   / Best Landscape Rake for the money? #1
Mahendra420
Member
Valdosta,Ga
Mahindra 2810
Just tried a Chinese brand worked fine pulling when pushing tho it folded up like an accordian.:thumbdown:
   / Best Landscape Rake for the money? #2
Check this one: Landscape Rake for Compact Tractors
Heard of those should I go with $620 or the $840 version in the 5 foot?
Tractors a 28 HP.
   / Best Landscape Rake for the money? #5
Tractors a 28 HP.
What are you raking?
Heavier is usually better. :thumbsup:
Debris roots logs leaves.
   / Best Landscape Rake for the money? #7
I have one from everything attachments that we have used a good bit. The weak point is around the pin pivot connection to the tooth bar. I've had to reweld the braces once and will have to do it again soon. Probably would be no different with another brand. Do take weight into consideration as heavier is better, not always in construction, but in use of the implement.
I'm an engineer and didn't know I think in a past life I worked for a German tank division that noticed stress.
OCD as well.
Those negative Waves.
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
2022 Diamond T 14' Dump Trailer, VIN: 5FWDS1423NR030358, Tandem Axle, 7 Gage Steel Floor, Power (A59076)
2022 Diamond T 14'...
TMA (A55973)
TMA (A55973)
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
