kioti nx6010 hst cab
   / kioti nx6010 hst cab #41
I think I see what you are saying Eric. I just looked at the treadle dampening cylinder on my newly dated 2012 CK35 HST, and it resides about 5" away from and above the hydro block. I imagine the hydro block is radiating some heat to warm up the dampener.
By the way, could you give a recommendation on a decent, valued priced, point and shoot thermo?
   / kioti nx6010 hst cab #42
For what we're doing, any of those cheap home-improvement store pyrometers work fine. The expensive ones are for specialized uses and are either more accurate, or more likely, have a much higher range (for example: determining the right temperature for pouring metal for foundry work). Here is a nice one for the money: Etekcity 8750 Digital Infrared IR Thermometer Laser Sight Range of -58F to 1382F, 12:1 D:S, Non-contact, Temperature Gun, CE/ROHs/FDA/FCC Approved - - Amazon.com
   / kioti nx6010 hst cab #43
Thanks.
   / kioti nx6010 hst cab #44
I looked it up.
2013 start with N, 2014 O, 2015 P. Next group will be N39 for NX6010CH followed by the number made. So my NX6010CH
serial number is NN3900044 for 2013, number 44. Odd since they where all announced as 2014 models.
Eric, I just bought a NX6010 in August 2014. Serial number PN3900033. What year is it ?
   / kioti nx6010 hst cab #45
P would be 2015. Did you go into the future, buy a tractor and return with it to the present? Seriously though, I don't see how you could possibly have bought a P tractor in 2014, those numbers indicate the actual year of manufacturer, not model year like automobiles.
   / kioti nx6010 hst cab #46
I am looking at a nx4510 at my local dealer that had been there since August and it's serial #starts with p.
   / kioti nx6010 hst cab #47
Did they Skip O (the letter O) to not confuse it with Zero? I know a lot of manufactures will skip O's and I's.
   / kioti nx6010 hst cab #48
They probably did, we are just going by what eric posted about the #'s. He is usually pretty good on his research so I figured it was correct.
   / kioti nx6010 hst cab #49
I recited what is printed in Kioti's own NX Series Service Manual.
2018 Kubota B2301 (A53317)
2018 Kubota B2301...
Mohawk TP-15 15,000lb Two Post Auto Lift (A55852)
Mohawk TP-15...
2019 CHEVROLET SILVERADO 11FT FLATBED (A57880)
2019 CHEVROLET...
2001 John Deere 4600 (A53317)
2001 John Deere...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
2015 Peterbilt 320 Trash Truck (A55973)
2015 Peterbilt 320...
