RTV 500 Adjusted the servo & X over Bed-Box
   / RTV 500 Adjusted the servo & X over Bed-Box #1
Tkblacktail
Gold Member
Well, I did it this afternoon and it worked. With all but one adjustments made, the thing jumps from an idle and the power transfers a lot better; I don't have to let off the gas for the hst to downshift.
Honestly, she almost broke traction on the wet asphalt. I still want to "make some room" by adjusting the throttle-stop at the engine as she peaks at 3,900 rpm, but I am glad it is done.
As usual, I painted parts of the tranny "blood-red"; I caught my knuckle on
something when I was removing the world's craziest looking cotter pin from the pedal cable assembly at the bell crank. :laughing:
Thanks to all the posts and info on this, I would not have known. I really appreciate being in this forum.
I also mounted an X-over bed-box that I made off some shop-floor cedar and fir; I still want to paint it a foliage color, but I plan to load it up with chainsaws, fuel and tools next week and break it in.
   / RTV 500 Adjusted the servo & X over Bed-Box #2
Good deal. It's amazing the difference the adjustments make, mine will take off spinning the tires in dirt now. Not sure about pavement my buggy hasn't seen any yet.:laughing: If dealers set all these units up this way prior to delivery I think they'd have a lot happier customer.
Your box looks nice, that gives you alot more room for stuff.:thumbsup:
   / RTV 500 Adjusted the servo & X over Bed-Box #3
Ok, so I have been considering these adjustments on my K 500 but i'm no mechanic. So how long did they take you? And do I need some fancy gizmo to measure RPMs and such for this task?
I did it once so now I appear to be a brand new 2nd Lieutenant when I make the claim:
"This is how I always do it".
:D
I used a 12mm for the linkage, a 13mm for the pedal stop in the cab and a short 14mm for the servo stop-nut. I had previously installed a tachometer in the dash where the speed-ometer belongs.
I basically followed the advice in these two posts:
http://www.tractorbynet.com/forums/...v500-hydrostatic-transmission-shifting-4.html
http://www.tractorbynet.com/forums/atvs-utility-vehicles/155957-rtv500-throttle-adjustments.html
There was some discovery learning on the cable adjustments; I didn't know which way the lever would move, so I went back and fourth a couple times. I used a telescopic handle (pressed against the seat) to hold the pedal to the floor.
I was done with everything (except the throttle-stop adjustment at the engine) in about an hour. The engine piece of the project looks easy except for all the wires and stuff in the way. Thats real close to where I affixed the inductive pickup clamp for my tachometer. My RPM is right at 3,900, it feels like I need to make room for the increased cable travel at the engine.
This thing is pretty tough, as long as the pedal-stop in the cab "bottoms out" before the lever at the servo..........
It is worth it.
Another thank you to the help I get in this forum.:thumbsup:
   / RTV 500 Adjusted the servo & X over Bed-Box #5
Bump to an old thread. We got our 500 in October. Has 100 hours on it now. Overall it's a good machine. Best tool for plowing our 1/4 driveway. My wife uses it daily to take hay out to the horses (small squares). We were between the rtv500 and a Ranger. We went with the RTV because our 10 and 13 year old drive it. The ranger was just too fast for them. The RTV500 top speed is fine on the flat, but power was lacking on the hills.
I went ahead and made the adjustments today and it's like a new machine. This is a must do for for and rtv500 owner.
   / RTV 500 Adjusted the servo & X over Bed-Box #6
Glad that is working for you...Just surprised that the OEM hasn't made that a factory adjustment by now. I did my RTV500 in 2009 or so..Still miss that thing, it was a great general use machine.
KUBOTA KX057-5 EXCAVATOR (A52709)
KUBOTA KX057-5...
2024 FORD F250 SUPER DUTY BED (A58018)
2024 FORD F250...
2005 UD Truck UD1300 Landscape Dump Truck (A56858)
2005 UD Truck...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
