NH 3010 Hydraulics
   / NH 3010 Hydraulics #21
I'm not sure about either question. I have a operators manual on the way. When I bunji the remote open the lift does not work. I don't know what detented remotes are. Sorry.
   / NH 3010 Hydraulics #22
A remote with a detent can be opened and the kicked into a hold position, yours apparently are not detented.
Hey guys, I am the one that started the thread....and I am surprised to see it open back up. My 3010 "S" was bought because it was offered to me at a cheaper price than I could buy a loader for my TN75S. I use it strictly for the FEL and have been very happy with it. It has a lever that is on the back that I pull forward into a clip that makes the hydraulics go away from the 3 point hitch operation and work only the loader. Is that what is considered a detent? I am planning to load the rear tires with water this year to keep the back end on the ground better with really heavy loads. Should I put windshield wiper fluid in instead of water? The beet juice is not available in Alabama. We don't have many days below freezing.
   / NH 3010 Hydraulics #24
Thanks for the information. I'll investigate further. Just learning about this tractor.
   / NH 3010 Hydraulics #25
Is there a way to operate a front loader on the 3010S without having to hold down the hydraulic lever? Also will the lift work independently of the hydraulics? Thanks.
Yes there is a power beyond that can be purchased through New Holland piece by piece. I completed the process two years ago. Now I can use the front end loader and the rear remote at the same time.
   / NH 3010 Hydraulics #26
You describe a diverter, I was referring to a remote with a hop open detent.
Not the same
   / NH 3010 Hydraulics #27
Response to your comments of 01-03-2015
I bought a Ford 1920 (sweet little tractor/loader) last fall. It had calcium chloride in the rears, and the rims are rotten!
I bought new rims, and am still looking for -20F windshield washer fluid at a good price. There is a graph available for tire size/ gallons required, and I need about 80 gallons (40 per tire).
Currently the tires have only air, and I am using my 3pt hitch forks with a pallet, and a water drum for ballast.
"Beet juice" is expensive ($3+) per gallon), and from a corrosion standpoint, calcium chloride should be avoided at all cost.
Used automotive anti freeze is a no-no for the potential pollution issue, and non toxic RV anti freeze is too expensive.
-20F windshield washer fluid is the way to go for me, but I can't seem to find it at a price that I like.
I keep my tractor at my Massachusetts summer home, and want to winter store it with -20F windshield washer fluid in the rear tires.
Have you had any success in your particular area locating windshield washer fluid at a good price?
I am looking for -20F fluid at about a $1.50 per gallon price. At 6 gal. per case, I need 13-1/3 cases ($81+?).
Walmart is probably going to be my best bet, but I am in Florida each winter, and far from any Massachusetts Walmart.
Hopefully I can find it somewhere in MA. or NH., before I head South for the winter..
548 (A52708)
548 (A52708)
(2) VINTAGE TROLLING MOTORS (A58374)
(2) VINTAGE...
2020 Ford F-250 4X4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
