holes in side of bucket?
   / holes in side of bucket? #11
1. ? let water out ? Soundguy
2. ? break suction ? Soundguy
3. To attach something (like a limb saw or 999 other things)? CobyRupert
4. When I bought my tooth bar, I had to drill new holes, since its bracket didn't align with the existing holes in the bucket sides...but maybe Kioti makes a tooth bar specifically to fit there and use those holes? rd_macgregor
5. mounting holes for a bracket, that connects to hyd cylinders, for a full bucket grapel?
6. the new "wash me call it" camera that fits inside the bucket or on the outside of the bucket, for better view of what your doing?
7. mount holes for some snow skies, so you do not gouge / scratch up paved or concrete driveways?
8. the bucket was blonde color (primer) before it got painted black, and had some airy issues
9. head penny pincher, said it would save them 1,000,000 bucks if they did this on shipping costs. (reality of story it cost them 5,000,000 in lazer cutting and new machinery to put the holes in)
10. actually!!! *hhmmmss* eyes the bucket on the old 555c TLB outside... bicycle tire and a pin... to move bucket into a different spot in garage for storage..? *gives it a try and bucket flips over creating above ground metal grave*
   / holes in side of bucket? #12
1st two were to calibrate their hole saw, 3rd was to then do a test drill.:D
   / holes in side of bucket? #13
Permanent camera mount. Clamps sometimes slip.
Bruce
   / holes in side of bucket? #14
Did you buy it new or used. If used, then the previous owner drilled them for some attachment he had. If it came from the factory like that then Kioti must have some attachment that bolts to it. Or they could be for any of the previously mentioned posts.
   / holes in side of bucket? #15
The only use we have seen for them is in shipping the Front Loaders. The buckets are shipped standing up on the shipping pallet. There are lag bolts through the holes holding the bucket to the pallet.
Thank you for an answer! A lot of funny guys on here!:)
   / holes in side of bucket? #17
Thanks for an answer.. by the way I lied in my post when I said it only had one hole on each side, it has 2. I looked at it again today.:)
   / holes in side of bucket? #18
Yep, that's what my dealer explained to me when I asked about the predrilled holes in the sides of my standard bucket a few months ago. Mine are in a different place, as the bucket itself is different from the OP's.
   / holes in side of bucket? #19
The holes are there specifically to keep us amused and confused. I drilled them about a year ago.
   / holes in side of bucket? #20
When that bucket fills from water because of a heavy rain when it was left out, use them for the sump pump lines,,,,I know, you didn't choose the front sump bucket pump option, wtg!:D:laughing:
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
Hydraulic Cylinder (A56469)
Hydraulic Cylinder...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
2018 Dodge RAM 3500 (A53317)
2018 Dodge RAM...
2012 Ford F-150 Ext Cab 4x4 Pick-Up Truck (A55852)
2012 Ford F-150...
