Accessory plug on Kubota?
   / Accessory plug on Kubota? #12
I'm planning to put the switch in the fender, because easy.
That's where I wish I had installed my accessory outlet....installed in on the key panel instead. Just make sure you use a marine type outlet for better protection from the elements.
Found what may be the perfect switch - sealed motorcycle on/off switch.
Trail Tech 040-LS-B Black Push Button Light Switch. Available on Amazon.
I am thinking I'm going to drill a hole in the metal bracket that holds the tool box, near the right fender.
West Marine sells the similar Perko switch.
   / Accessory plug on Kubota? #16
Ha,ha,ha. Almost caught me on that question. I know from experience that there are about X100 different plug types. I went to my local NAPA store, got matching male/female plug set. Clipped off the Kubota provided plug and used the mated set for the connection. Easy as pie.
Well, I've been to two auto parts stores (Advance and NAPA) and neither had anything that looks like this.
Tried Radio Shack, they had some two pin connectors but not 90 degree and not locking.
   / Accessory plug on Kubota? #19
I just used 2 normal crimp spade connectors. Worked fine while I had it temporarily plugged in there, wasn't sealed or heavily secured though.
I've done a fair amount of boat [in salt water] and motor cycle accessory wiring. When I first started, it was "Whatever will get me back on the road/water fastest."
After learning the error of my ways, I'm now in the solder/dielectric grease/heat shrink tubing school. Once I connect it I don't ever want to think about the connection again, ever.
...Do want to use a connector for this though as I'm not sure how I'll like the light.
(2) Safemack 18.4-38 Tires w/Rims (A56469)
(2) Safemack...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
UNUSED FUTURE KH72 72" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE KH72...
UNUSED FUTURE CW59 59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE CW59...
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
