Anybody with a ck20 have this issue?
   / Anybody with a ck20 have this issue? #1
mpham
North/central Massachusetts
Kubota B 2650 cab
I have a 2006 with 426 hours on it. All filters/oils have been changed at the proper intervals. Mine puts out so much soot from the exhaust that the loader arm and air filter are covered in thick black yuck in no time flat. Are yours the same? Runs and starts fine even in cold unheated garage.
   / Anybody with a ck20 have this issue? #2
It's perfectly normal on the CK20 to see that. It seems to happen when they are cold started and burning a bit dirty. I think you would see it on more tractors if the exhaust blew right at something like the loader arm but most blow out into the open.
   / Anybody with a ck20 have this issue? #3
Smoke will blow on our ck30 loader arm when you first start it so I just raise the bucket as soon as I can .
   / Anybody with a ck20 have this issue? #4
many makes and models do that. My brother's CK20 does, and My Mahindra does. I'm thinking of turning the end of my exhaust pipe down with something like the chrome tail pipe extensions we used to put on our cars.
like this, only smaller:
   / Anybody with a ck20 have this issue? #5
Mine was built in 2011 and it does the same.
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
71062 (A49346)
71062 (A49346)
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
