George2615
Super Member
I have an 8' (actual size is 7' 6") snow pusher. I live in the snow belt of Upstate NY just S.E. of Lake Ontario. In the beginning of the snow season I just use the tractor and pusher. As snow fall increases I add chains on all four and an 850 lb. rear ballast. You will need traction to push or plow snow. I also added an adjustable height back drag blade to my pusher made from an old truck plow blade cutting edge so I can pull up to the garage, rotate it 90 degrees and back drag the snow. My pusher has a double sided adjustable height steel blade. I have it set 1/4" higher than the sides so it doesn't dig in to the gravel driveway. Pusher blade weighs about 700 lb.
$1000 for a pusher IS a great price. My pusher cost $1500 and a larger one is about 2K.
