Mowing Newbie question about bushhog and finishing mower
   / Newbie question about bushhog and finishing mower
Thanks for all the replies, I ran the finishing Mower at 540 at around 2000 RPM yesterday for a few hours and it was fine, no overheating and definitely not as loud, it cut the grass fine. I plan on using the big mower more this weekend, probably at 540 also to cut some more of the rough stuff. I guess I need to keep the tractor geared where the engine RPM are around 2000, that's where the green line is on the tach. I think I was running it a too low an engine RPM while I was mowing at 1000 rpm before, maybe that why it got so hot.
I have two levers for High/Low on on the tractor, one on the transmission area next to the main shifter and the other more under the seat. I am not sure the difference of these two range settings other than the gearing of the transmissions, I have read there are 12 forward and 4 reverse gears, that would make sense (its a three speed, with the two range shifters). I guess I need to plan to just keep the engine RPM around the green mark whenever I mow.
   / Newbie question about bushhog and finishing mower #12
There is a certain work function involved in what you are doing with associated losses. To remove these losses from the tractor you need a certain amount of air across the radiator coils. Running too low an engine speed with a high work function can do as you experienced. Get your 540 lever engaged and run your engine at the green line unless you can see that dropping off 10% to get quieter operation won't result in overheating.
Agree with others on fluid changes including radiator flushing and new 50-50 coolant. Flushing out the fins/tubes is also usually a daily event under dirty conditions and "hogging" is usually just that.
Mark
Thanks again for all the responses, the tractor was recently maintained. I am now mowing at 540 with the engine at about 2400 RPM, she'd running fine!!
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
2019 Harley Davidson (A56859)
2019 Harley...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
golf cart (A55758)
golf cart (A55758)
