What do you use to lubricate the 3 point hitch assembly?
   / What do you use to lubricate the 3 point hitch assembly? #1
jodebg
New Hartford, CT
Kubota B-2650
Wondering what is the best lubricant to use on the 3 point hitch assembly?
Recently read about a wet graphite spray...is this product better than other
to use on the moving parts on the 3 point hitch?
   / What do you use to lubricate the 3 point hitch assembly? #2
I am a wd-40 and duct tape person, myself.
Where do you use duct tape on the 3 point assembly??
   / What do you use to lubricate the 3 point hitch assembly? #4
Right or wrong...I use Fluid Film, it doesn't have the solvents that most spray lubes have so it lasts much longer. It's great for all linkages as well.
   / What do you use to lubricate the 3 point hitch assembly? #5
+1 on the Fluid Film.
Sent from my iPad using TractorByNet
   / What do you use to lubricate the 3 point hitch assembly? #6
+2 on the Fluid Film.
Also use it on the PTO spline.
   / What do you use to lubricate the 3 point hitch assembly? #8
Graphite would be the better choice, the other choice would be use nothing. Any kind of waxy or oily coating is just going to attract dirt which will work just like sand paper to wear out the joints faster than using nothing.
   / What do you use to lubricate the 3 point hitch assembly? #9
fluid film here. The best I have ever seen for this application. I also use it on the SSQA linkage up front.
   / What do you use to lubricate the 3 point hitch assembly? #10
I use the JD dry lubricant spray. It lubricates but stays dry to the touch so it doesn't attract dirt and debris.
17101 (A55787)
17101 (A55787)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
Deere 35G (A53317)
Deere 35G (A53317)
2023 Kubota RTV-XG850 Sidekick (A56435)
2023 Kubota...
Sellick 560 Forklift (A57148)
Sellick 560...
