Ford 1720 with 6' Bush Hog RDTH72 finish mower?
   / Ford 1720 with 6' Bush Hog RDTH72 finish mower? #11
Keep your blades sharp and it will handle it. I have a 5' Land Pride on My 1720 and have been through a lot of tough grass. Bahia grass is really thick and I have to slow down a little but it handles it.
GAry
   / Ford 1720 with 6' Bush Hog RDTH72 finish mower? #12
GAry
We have plenty of Bahia and Bermuda, so I'll have to keep the blades sharp. Now it's just a matter of finding a used mower at a reasonable price locally. That bush hog I mentioned earlier was pretty beat up.
Thanks for all the advice!
   / Ford 1720 with 6' Bush Hog RDTH72 finish mower? #14
A 6' rough cut mower is too heavy and too wide for your 1720 except in IDEAL conditions. Get a 5' cutter.
SDT
I'm not following on the too heavy part. TractorData.com shows 1742# lift capacity on the rear for that tractor; a 6' mower weights 600-700#. What am I missing?
Edit: I see you say "rough cut" - I'm not looking at a rotary cutter/shredder, but a finishing mower. Maybe that's the difference?
Over the weekend I found and bought a used 6' Land Pride FDR1672 finishing mower for $1125. Hooked it up after checking the oil and grease fittings and mowed my 3 acres on Saturday. It handles fine - I mowed in 3rd/2nd on the shuttle (would that be 8th gear?) for the open areas that weren't too tall, and shifted down to around 2nd/1st on shuttle (4th) gear for a few places where it was really thick and taller (8"+).
   / Ford 1720 with 6' Bush Hog RDTH72 finish mower? #17
Nice mower - looks good, useful! Enjoy it!
   / Ford 1720 with 6' Bush Hog RDTH72 finish mower? #18
Watch the temperature gauge. A bigger deck will work but may overheat it when pushed hard.
Steve with a 72" finish deck on a 1900 (and it will overheat in tall grass pushed hard)
Thanks Steve. I actually was watching the temperature gauge and it never budged after it warmed up. So looks that I wasn't pushing it too hard.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
500BBL WHEELED...
2010 International Digger Derrick (A55973)
2010 International...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
