Comparison Yanamar LX4900 HST vs Kioti Dk45se HST
   / Yanamar LX4900 HST vs Kioti Dk45se HST #61
I like the yellow. Nice tractor.
   / Yanamar LX4900 HST vs Kioti Dk45se HST #62
well, I just made myself choke a little each year -- and i have always been batty enough:)
I want to be batty like that. Just trapped in a scardy kat frame of mind. One of these days I am going to get a back hoe with a fur lined seat.
And today my top n tilt arrived. Easy install (no small thing for me..... My brothers say I could wreck a steel ball bearing with a rubber mallet). Everything working perfectly but then it rained. More play time later in the week.
   / Yanamar LX4900 HST vs Kioti Dk45se HST #64
Pictures please. If you can get the Yanmar in the pictures too, that would be super. I really like your tractor.
Okay here is a pic of my new top -n-tilt (courtesy of Fit Rite Hydraulics -- Thank You!).
Bonus pic shows the tool box I mounted today. A bit home-made in the thinking, but I built a cradle for the tool box so I can lift the tool box out when I want. The cradle was made from an old open-top plastic box/case, cut in half then separated by just about 16 inches to accommodate my channel lock tool box -- 26 x 10 x 10 -- and then mounted the plastic on a wood frame made from scraps found round the shop. I halved the plastic box so I have an opening to look through when I remove the tool box and can see down to the three point hitch without removing the cradle.
I did a large cutout in the plywood base on the bottom of the cradle so that I can remove the gas cap and fill the tank without removing the cradle. Works well! (Have burned through my first 25 hours on the tractor pretty quick and had need for a refill).
Cradle mounts with one bolt through an open hole in the ROPs, and rests on industrial strength velcro attached to the tractor and the bottom of the cradle frame (so nothing gets to rub on the pretty yellow tractor). And because the tractor is new I even painted the wood frame yellow to sort of match.
I know that I am new to tractor stuff and it seems like a bit much, but I had already filled up the tiny compartments they put on the tractor and needed a home for a big wrench, chains and odds and ends. Looked on this site and the internet to purchase something but seems like no real products out there.
NEW Fork Extensions (A59000)
NEW Fork...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
2018 John Deere 1653 (A56436)
2018 John Deere...
2011 Peterbilt 365 Altec AC38-127S 5-Mast 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Truck (A56858)
2011 Peterbilt 365...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
Globel Industrial 44" Water Cooled Fan, 24" Electric Pedestal Fan (A59076)
Globel Industrial...
