72" Piranha Tooth Bar Install and Review!
   / 72" Piranha Tooth Bar Install and Review! #61
My Kioti bucket has several holes pre-drilled along the cutting edge. My only guess is Kioti makes a bolt-on for the bucket. Yes? Tooth-bar or something else?
Those are for the bolt on replaceable optional cutting edge.
   / 72" Piranha Tooth Bar Install and Review! #62
I don't see this on the Kioti web site. Is it just another straight-edge for when the factory edge is destroyed?
   / 72" Piranha Tooth Bar Install and Review! #63
Just ordered my PTB from Harry. 65" wide. Feel like a kid at Christmas. Oh the anticipation.
   / 72" Piranha Tooth Bar Install and Review! #64
Yes it is just a straight edge.. your dealer should be able to price that for you.
Both the RR and Piranha sound like great tools. From the design, it seems the Piranha would need to be removed far less often - and it does at least "some" of the same tasks as the RR.
Yes I think that's a very accurate statement.
Sounds good! Hope you enjoy. So far mine has worked great... Have around 2.5 hours on it. Haven't destroyed it yet! Lol
   / 72" Piranha Tooth Bar Install and Review! #67
There is great feedback in this thread. I was about to pull the trigger on a Piranha, but decided to try making one. I did it more for the fun, than really trying to save money and I think the actual Piranha tooth bars are a great deal. Here's my DIY thread in case anyone wants to check it out. Thanks again.
http://www.tractorbynet.com/forums/power-trac/310891-cheap-diy-tooth-bar.html
   / 72" Piranha Tooth Bar Install and Review! #69
My Piranha for my Max25 came in the mail yesterday and I drilled and bolted it on. It only took about an hour. I put it immediately to work digging in the dirt and all I can say is WOW!!!!!
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
STORAGE FEES (A51219)
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
