Adding a turbo to my Old Ford 861 Diesel ?
   / Adding a turbo to my Old Ford 861 Diesel ? #1
Hillbilly Delux
Ponca City, OK
Ford 861 D
Hey to all here at TBN I am a long time reader and first time poster.
I am in the process of rebuilding an old Ford 861 diesel and was thinking about adding a turbo to it. Has anyone seen or heard of anyone doing this? Also any pros/cons or anything I should be concerned about or take into account?
Thanks in advance to all the great resourceful people here.
   / Adding a turbo to my Old Ford 861 Diesel ? #2
post up all your steps, I'd love to follow along.
   / Adding a turbo to my Old Ford 861 Diesel ? #3
First off, welcome!
Second, why in the world would you want to add a turbo to an 861? What will you be able to do afterwards, that you can't do now?
First off, welcome!
That's a good question. Maybe a four bottom plow? I just figured since I am going through the motor and giving this tractor a little TLC at the moment why not add a turbo? Factory specs between a gas version and a diesel version rate the gas version higher in h.p. and tourqe even though they are 172 cu inch engine. I was thinking maybe I might get a little more of both plus maybe even getting slightly better fuel economy than I already have from a cleaner more efficient combustion with out sacrificing the longevity of the motor. Just weighing the options right now I haven't decided yet if I am gonna do it yet or not. Plus the coolness factor.
First off, welcome!
   / Adding a turbo to my Old Ford 861 Diesel ? #6
A turbo would give more power, but your still limited in the weight of the tractor.
   / Adding a turbo to my Old Ford 861 Diesel ? #7
The 861's less than robust crankshaft make it a poor choice for the additional combustion pressures and power production that a turbocharger would add. You want to modify a diesel engine, pick one that was designed as a diesel, not a spark ignition engine that was nothing more than a factory authorized diesel conversion.
I was thinking if I did turbo it I would need to add a stronger conecting rod and stronger head studs. Regardless wether I turbo it or not I am going to add me an oil cooler and maybe an electric higher CFM fan as the motor really was designed to be a gas guzzler and higher compression ratio of the diesel makes it run a tad on the hot side anyway.
   / Adding a turbo to my Old Ford 861 Diesel ? #9
My advice would to re-read RickB's post and heed that warning. You can't get more power and torque without increased loads on the components. Without knowing the design margins on the critical parts, it's a crap shoot from the engine longevity stand point.
   / Adding a turbo to my Old Ford 861 Diesel ? #10
Take whatever budget you have for this project, buy a six pack of beer and burn the rest of the cash in the backyard. You will still have a running tractor at the end. You are in way over your head. These 172 diesels don't run hot by nature, in fact Ford used a 2 blade fan to help boost operating temps to optimum levels.
2005 Ford Escape XLT SUV (A48082)
2005 Ford Escape...
1999 Allegro Bay Class A Motorhome (A48082)
1999 Allegro Bay...
2015 Jeep Cherokee SUV (A48082)
2015 Jeep Cherokee...
2021 John Deere R4038 Self Propelled Sprayer (A50657)
2021 John Deere...
2016 Ford F450 (A49461)
2016 Ford F450...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
