Buying Advice Leaning toward J D 1025r tractor mower loader.
   / Leaning toward J D 1025r tractor mower loader.
Thanks for the advice ,i was not considering a broom only a blower,i am hapy the auto conect works good and i am going to go ahead
with the John Deere.
I apreciate all the advice it is a hard choise to make i trust you people a lot more than the sails man's.
   / Leaning toward J D 1025r tractor mower loader. #12
You are welcome. Just remember - TBN'rs work for pictures!! :drool:
There will be pictures soon ,went in the J D dealer this afternoon to ask more questions .
Tried one out in the yard .
Shooke hands with the sallesman ,dooing paper work next week.
Going to decide this weekend if i get the backhoe , the anser is yes for now but i will sleep on it.
   / Leaning toward J D 1025r tractor mower loader. #14
Deereman, Yes, please take some pictures of the auto connect removal procedure. Hopefully it will reduce the amount of "bad language" I direct toward John Deere engineers when I remove it. Again, I'm a big fan of auto connect but I have the 52" broom that I would probably use more during the mowing season if it was a bit quicker to switch back and forth.
   / Leaning toward J D 1025r tractor mower loader. #15
I have the 1026r with the 60" auto connect deck and wouldn't be without it. I found that if I try to attach the deck on the concrete driveway the deck slides away from the tractor. So now I always attach and detach on the gravel approach to my shed. But as the videos show, it is about 45 seconds to attach and about 30 seconds to detach.
There is a down side to the auto connect feature however. If you are switching to a front mounted attachment like a snow blower or broom, you have to removed the auto connect attaching hardware. Its not overly time consuming but you pretty much have to lie on the floor/ground to remove the pins and pto shaft. With a friend on each side it removes fairly quickly. But by yourself if can be more of a challenge. If you are making the switch once in the fall over to the blower and once in the spring back to mower, probably not a big deterrent. But if you have a front mounted broom that you would like to use several times during the mowing season then one might want to reconsider the auto connect option.
But as I get older lying on my side with the mower wheels digging into my ribs trying to attach the mower pto shaft to the tractor, I find the auto connect feature one I would never give up.
So removing and installing the deck on 1 series is not that much faster than the BX.
i will soon find out
   / Leaning toward J D 1025r tractor mower loader. #17
Still not as easy as driving over it....and it might get to the point where I will have trouble doing that....hope not...but there is always the kid next door.
Also I was told as the parts wear on the 1series they get a little fiddley to get on.....don't know if that is true or not...but just tossing that out there.
Also the 3 series machines have drive over decks....but I think it is only on the 72" deck.....I cant remember for sure now....but it sure is a nice feature.
   / Leaning toward J D 1025r tractor mower loader. #18
Congrats on the new tractor.
That was a great video:laughing:
   / Leaning toward J D 1025r tractor mower loader. #19
Will do. I plan on taking off the blower & putting the broom on this weekend. I suppose this will cause a blizzard to occur?
:tropicalstorm:
Mower deck should be in another week or two.
   / Leaning toward J D 1025r tractor mower loader. #20
DeereMann, don't do it, it will storm for sure then!
2015 Freightliner M2 106 AWD Versalift TMD2047T Insulated Digger Derrick Truck (A55973)
2015 Freightliner...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
JOHN DEERE 348 SQUARE BALER (A58214)
JOHN DEERE 348...
2020 CATERPILLAR 289D3 SKID STEER (A52709)
2020 CATERPILLAR...
