Oil & Fuel Oil Filter Change Frustration (This is a rant)
   / Oil Filter Change Frustration (This is a rant) #1
Trails End
Gold Member
Candia, NH
Bobcat CT335
I just completed an oil and filter change on my Bobcat CT335 (100 hrs).
Draining the oil was no problem, but as usual, removing the old oil
filter was a frustrating experience, as it is with most vehicles that I've
changed filters on. WHY CAN'T MANUFACTURERS PLACE THE
FILTERS HANGING DOWN, INSTEAD OF SIDEWAYS????
No matter how careful I am, I still end up with a substantial amount
of oil leaking down on frame members and/or on the garage floor, or
on myself. While removing the filter from the CT335, despite all
efforts to minimize spillage, I ended up with about 1/2 cup of oil on
the axle housing, floor and the sleeve of my jacket before I could
get the filter upright and out of harm's way!!!!
Anybody else share my frustration???
   / Oil Filter Change Frustration (This is a rant) #2
How about next time you put your pan under the filter and punch a hole in the filter (bottom outer edge) and let it drain before removing it. Might just work. Jack.
   / Oil Filter Change Frustration (This is a rant) #3
I used to have a tractor with a two quart oil filter mounted upside down and partly over the engine. Not only was it a two qt mess every time I changed the oil but it also drained all over the side of the engine so it could drip and smoke later. Good grief.
It seems that what we need is a self-sealing punch with a spigot on it. Punch a hole at the lowest point on the filter,
and then open the spigot to direct the oil to a container.
   / Oil Filter Change Frustration (This is a rant) #5
In hot rods you can easily plumb in a remote filter and put it where you want and any angle that suits. It's crossed my mine on a couple vehicles I have owned.
I was thinking about the same thing! On the CT335, the oil filter mounts to an interface
that is mounted to the front of the engine block, as shown below.
I think that it could have just as well been mounted with the filter in a vertical position.
   / Oil Filter Change Frustration (This is a rant) #7
On my DK for the motor I cut a thin piece of cardboard and make a trough that I slip under the oil filter and angle down and towards the rear of the front axle.
Works well, couple drips is about it.
   / Oil Filter Change Frustration (This is a rant) #8
I feel the same frustration when changing antifreeze. Changed the antifreeze in my JD 820 Saturday. Antifreeze all over the floor.
   / Oil Filter Change Frustration (This is a rant) #9
Yep. problem solved
   / Oil Filter Change Frustration (This is a rant) #10
It's not a problem, it's a "feature". Dual purpose oil change and bug fogger ;)
Land Pride SGC0554 (A56469)
Land Pride SGC0554...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A55973)
2012 Chevrolet...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
