Tires Kubota L 4330 Need turf tires
   / Kubota L 4330 Need turf tires #11
Kenny, How high can you bring your "rpm's" up with the foot throttle?
   / Kubota L 4330 Need turf tires #12
I've got a l4330 with turf tires on it. Firestone, backs are 14.9-24, fronts are 9.5-16. Have 2000 hrs on them and they work great. Use it for commercial landscaping and snow removal.
   / Kubota L 4330 Need turf tires #14
I have "Oversize" turfs on my L4200, 16.9x24-6ply & 12x16.5-8ply that is the Largest combination I could get to fit And keep the Front Rear Ratio correct.
I do like Your front fenders. Turf tires give the Best traction on grass dirt snow & Ice.
   / Kubota L 4330 Need turf tires #15
I have what you need just shipping would probably kill us!
   / Kubota L 4330 Need turf tires #16
If it were me, for the short term get a set of chains for the front. If you find yourself getting stuck and using the chains a lot, then swap the tires.
Also, adding some more ballast would help traction except in very slippery conditions.
   / Kubota L 4330 Need turf tires #17
Just checked... 750/800 RPM at idle up through 2900 RPM with hand OR foot throttle and I use the foot throttle on everything except constant PTO driven jobs like mowing, for those jobs I preset PTO rpm... KennyV
   / Kubota L 4330 Need turf tires #18
Thanks so much, Ken,,
I've adjusted mine but just can't get it up past 2000,
I think the linkage may need some attention.:thumbsup:
   / Kubota L 4330 Need turf tires #19
   / Kubota L 4330 Need turf tires #20
IMG_1190.jpgI have 21.5-16.1 R3 Turf tires on rims that are calcium filled. I will trade for 14.9-24 R1 tires on rims. These have 600 hours and are in great shape. Also included are the front tires and rims. mine are on an L4330HST Kubota.
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
2019 SPM 2500HP QUINTUPLEX FRAC PUMP (A58214)
2019 SPM 2500HP...
2014 Freightliner M2 106 AWD Altec DM48BTR Insulated Digger Derrick Truck (A55973)
2014 Freightliner...
2024 ArmorLite Aluminum End Dump Trailer (A56435)
2024 ArmorLite...
Spreader Attachment (A56859)
Spreader...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
