Comparison Yanamar LX4900 HST vs Kioti Dk45se HST
   / Yanamar LX4900 HST vs Kioti Dk45se HST #11
You need to go back and give the yanmar price to the Kioti dealer and ask for that 2000 off.. He is priced way high to begin with, and if you get it, buy the Kioti.
   / Yanamar LX4900 HST vs Kioti Dk45se HST #12
I don't have knowledge of either. So I will toss in an unqualified vote for the underdog... Yanmar.
sounds like a plan, thanks -- and if i then end up with the Yanmar i can blame kioti (the Yanmar sure is pretty). On a side note, what do you think of the wicked grapple? And why did you chose that size?
   / Yanamar LX4900 HST vs Kioti Dk45se HST #14
I would never buy a wicked grapple unless I had a small tractor for which they are fine. The 30" opening is way too small for my needs.
   / Yanamar LX4900 HST vs Kioti Dk45se HST #15
Help me, I am a newbee..what do I use two for? Seems I have one installed for the backhoe, will be adding a line to the loader so i can use a grapple. but why else two?
Lots of people like them for having a hydraulic top link, and hydraulic tilt (raises/lowers one lift arm)....commonly called top and tilt or top N tilt, etc. It doesn't sound like much, but they can really make life easier for some jobs.
Similarly, if you ever buy a 3pt snow thrower, you can control both the chute angle, and deflector shield with hydraulic remotes....rear forward pull snow throwers sometimes even have a small scrape blade that can be run on a remote as well.
If you can think of it, somebody has found a way to run it off those rear remotes!
   / Yanamar LX4900 HST vs Kioti Dk45se HST #16
I discovered the Yanmar line while going to check out Kiotis. The dealer, who was selling both, actually steered me over to the Yanmar. The dealer told me he was having trouble getting Kioti tractors and there seemed to be a lot of drama of Kioti dealers being dropped, at least in my area of the country. The regional Yanmar rep was also onsite, so maybe that also had something to do with it.
I test drove both the DK45 and Yanmar LX4900 while I was at the dealer. The Yanmar seemed more comfortable and easier to maneuver. I had never heard of Yanmar until that point, but the more I dug into their 100 year history, and their relationship with building tractors for John Deere, the more I became interested in them.
As for the Cub Cadet thing, selling Kioti built tractors didn't work out for Bob Cat. And before Cub Cadet was selling Yanmars, they were selling Kiotis. I guess Kioti didn't work out with Cub Cadet either. I don't think it really matters. Yanmar has stood behind the tractors they built for Cub Cadet and still warranty and support them. Note, the LX4900 was never a Cub Cadet branded tractor, it was only released under the Yanmar name and will only have Yanmar part and serial numbers.
Don't be fooled by the weight differences of the tractor. The Yanmar is a stout machine and there are no aluminum parts that I can find. The transmission and axle housings all attract a magnet. It does save some weight with its polymer hood and fenders, so you know more of its weight is where it counts, in its frame a drivetrain components.
Yes, expect to pay about $1100-$1200 for the dual-rear-remote kit. Soon I will be writing up the install of this kit on my LX tractor.
The Yanmar LX has a loader level indicator. It's on the inside of the right loader arm.
Re fluids, sight balls, etc. My Yanmar LX hasn't leaked a drop of gear, engine, or hydraulic oil so far in almost 150 operating hours. The front axle has a dip stick that threads out. The engine and gear oils are checked on the "cold side" of the tractor away from any hot exhaust parts. The hydraulic/transmission fluid is checked by a dipstick in the rear. I performed the "free" 50hr oil and hydraulicfluid and filters myself, it was pretty easy. You'll want a bucket pump for the hydraulic fluid. Quarts of oil stand up by themselves on the oil-fill port which is nice if you're trying to get every last drop of oil out of the quart container.
I do believe, with its direct-injection, the Yanmar engines are more fuel efficient than the Kiotis. And I've said before, the Kioti engine has a bore and stroke suspiciously identical to the Kubota engine. That tells me some engineer was doing more copying than innovating. With the Yanmar engines, however, you do see a little more PTO hp loss, I'm not exactly sure why that is, perhaps it has to do with the fact the Yanmar engine is a more square/power stroke design, so its putting out less horsepower at PTO speed while the engine is actually capable of higher rpm speed than the Kubota/Kioti engine. Or perhaps Yanmar is just being more honest about its PTO horsepower. In any event, my LX4500 can run a 6 foot bush hog just fine, on steep hills, so I'm happy.
I'm not going to try to address turbo/vs non turbo, but if you decided non-turbo you could always get the LX4500 model.
Look into the synchro-throttle feature. I don't think the Kioti has this. With the synchro-throttle you can control the engine speed with the foot pedals, like a car.
You may be interested to know that the Yanmar LX backhoe is actually made here in the USA by Amerequip in Wisconsin. Here's a link to a picture of the loader on their production floor:
http://www.amerequip.com/assets/images/photos/galleries/production/amerequip-collection-14.jpg
That's all I have for now. Hope that helps!
   / Yanamar LX4900 HST vs Kioti Dk45se HST #17
Yanmar has been making diesel engines for a LONG time, since 1933. I even have one of their 6 hp air cooled diesel engines. They are very good.
http://us.yanmar.com/products/industrial-engines/
   / Yanamar LX4900 HST vs Kioti Dk45se HST #18
I like it, I did not need a larger one, as my loader is only rated for 1420 lbs. It is made from good steel and is tough but lightweight. Every extra pound you put in a grapple, is a pound of materiel you cannot lift.
Yes the opening is only 30 inches, but when loading brush, just go down on it with the grapple dumped down so you squash the load of brush down before you clamp it. It works well, you can get a load of brush you cannot see around.:)
As for loading rocks, anything over 30 inches around, is more rock than I can lift anyway. I also like the fact the tines come together precisely. I can pick up small sticks, or little rocks with it. I believe I could pick up a pencil with it, If I feathered the hydraulic cylinder to not crush it. Everyone has different needs, and there is no one perfect grapple, just like there is no one perfect tractor. A man should have 2 or 3 different styles of grapples, just like he should have at a minimum 3 or 4 different tractors.:)
People that do not own guns can never understand why a person would own a dozen or more different guns, but I understand:)
   / Yanamar LX4900 HST vs Kioti Dk45se HST #19
The good news is, no matter which tractor you choose, you are going to get a good tractor that will server you well.
   / Yanamar LX4900 HST vs Kioti Dk45se HST #20
They can be invaluable to control top & tilt cylinders if you will be doing much grading of about any kind.;)
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A55973)
2019 Chevrolet...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
