My Grand L 3240 cab tractor Step Modification byWaxMan
   / My Grand L 3240 cab tractor Step Modification byWaxMan #1
WaxMan
USA CT
Kubota Grand L 3240 cab BH 92 backhoe
I just separated this modification to make it easier to find. It's buried in with my other stuff and no real way to find it if someone wants to copy the modification in the future. Like TripleR did on his tractors step. :thumbsup:
So it's a copy and a 70 hr. update.
On my 3240 it's a long drop to the ground when getting out of the cab and I'm only going to get older. I always wanted to add another step like my tractors Big brother, the M series. I was going to order another step but why wait for one to come in, when I have two right now.
I took both steps off which are both the same right or left doesn't matter. I cut the first step off the step frame and cut it down 1 inch, welded it back on the mount before cutting the next step off the frame. This way I can have a pattern of the angle, to make it all the same at the factory angle.
Cutting it down 1 inch makes two steps look more evenly spaced and factory looking.
So it's now five inches lower then the original step and 13 inches off the ground (was 18 inches) but Oh so much more comfortable getting in and out. My subframe is 12 inches off the ground so the step is not the lowest thing hanging down.
Having the two steps, allows your body to end up in the same position, as it is when getting into the cab. As you step down, your able to turn your body with the extra step. Instead of just jumping off or trying to turn inside the cab on your way out.
I have to say after 70 hrs of use with this double step installed, this step makes a big difference getting in and out of the cab, mostly getting out.
Just a little worn paint but holding up well.
I never bought a step for the other side and I'm not going to, No need for one.
These are before paint and before some final fining touches.
This is with paint after 70hrs of use with this double step. Kubota factory spray can paint is pretty tough. Just takes forever to dry.
   / My Grand L 3240 cab tractor Step Modification byWaxMan #2
Re: My Grand L 3240 cab tractor step modification byWaxman
Great thread. Quality production as usual. I know what you mean about the paint drying. Even in my wood heated shop (desert dry) it still takes a couple days. :)
   / My Grand L 3240 cab tractor Step Modification byWaxMan #3
This is one of the best modifications I've had done on my tractor, my brother did the modification for me.
I was a bit concerned about bending it as mine is lower than yours, but while it has been hit a time or two there's been no damage. If it does, we've got welders and torches, so it can be fixed.
My son also uses this tractor as does my wife and they like a step on both sides, so I bought a new one. I don't remember getting in or out the right side.
If I ca find the time and a place to do it, I am going to have mine coated like BULLITT94.
   / My Grand L 3240 cab tractor Step Modification byWaxMan #4
Good idea. Besides, I never enter from the right side peddle, fel joystick in the way.
   / My Grand L 3240 cab tractor Step Modification byWaxMan #5
Thats sweet! I was taught @ norfolk county agricultural school (class of 1980) that you always mount a horse and tractor, from the left side only!
   / My Grand L 3240 cab tractor Step Modification byWaxMan #6
I've heard the left side referred to as the "onside"....and nobody uses the offside.
   / My Grand L 3240 cab tractor Step Modification byWaxMan #7
Another great mod, WaxMan,,:thumbsup:
I don't see how you can sleep at night now, not having a step on the other side,
what will the neighbors say...:p
   / My Grand L 3240 cab tractor Step Modification byWaxMan #8
I just separated this modification to make it easier to find. It's buried in with my other stuff and no real way to find it if someone wants to copy the modification in the future. Like TripleR did on his tractors step. 👍
Any chance of making one of these up for my new kabota 4060 Limited ?
   / My Grand L 3240 cab tractor Step Modification byWaxMan #9
I had the dealer put a double step on my L 3560 before I took delivery makes it. Uncheck easier to get in and out
2001 John Deere 4600 (A53317)
2001 John Deere...
Swict 7' Fork Extensions (A56469)
Swict 7' Fork...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
2018 Ford F150 (A55973)
2018 Ford F150...
2019 Nissan Titan Crew Cab Pickup Truck (A55852)
2019 Nissan Titan...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
