Pallet fork size - 36", 42" or 48"?
   / Pallet fork size - 36", 42" or 48"? #41
Think it goes without saying that forks capacity need to match up with your FEL capacity. 4000 lb. pallet forks on a FEL that can lift 2000 lbs. (at the FEL pins) is a waste of money.
And not to mention higher capacity attachments detract from your limited lifting capacity.
   / Pallet fork size - 36", 42" or 48"? #44
Glad this has been brought up since I have been thinking about buying some couldn't decide what length to get . I have been using my hay forks in pallets and they have been working but i know there not ideal .
Sent from my iPhone 5 using TractorByNet
   / Pallet fork size - 36", 42" or 48"? #45
Sometimes its not possible to match lift capacity to forks rating. Most forks come in either 2,000 lb or 4,000 lb capacity, but loaders capacity range from 750 lb to just under 3,000 lb. I believe that oversized is better than undersized. Less likely to cause damage. :2cents: Besides the difference in price is like $100.
   / Pallet fork size - 36", 42" or 48"? #46
It's only a waste of money if you could actually find forks rated for less weight that actually cost less...which I couldn't. I got the best deal I could find on a new set of high quality forks plus I got the benefit of a stronger, more durable set. Sometimes there's more than one right answer.
   / Pallet fork size - 36", 42" or 48"? #47
Used forks around here on craigslist and the auction sites seem to go for close to new prices. I have never seen a set of forks for sale for $100.
I just recently found two pairs (3000#/4000# class) on CL advertised for 60 each (40" and 48" as I recall, admittedly well worn at the heels, but perfectly suited for homeowner/small tractor use, imo) and bought a different set for 50, only a half hours drive away. fwiw.
Full disclosure, the pair I bought are 48" rated 8000#, 330# for the pair, my little loaders full height at the pin capacity is 700# :rolleyes: I figured by the time I welded up a frame and hung the forks I could use them to run down and get the mail :confused2: These are being incorporated into a 3 pt rig for now to move a pile of large rocks I have, then getting the tips cut off and becoming the basis for a ballast box where their weight wont be a bad thing. :dance1: (after I find a more suitable set for the front, of course...)
MB
   / Pallet fork size - 36", 42" or 48"? #48
MB
[/I] I know a lot of people find great deals on craigslist. I just havn't been that lucky. Craiglist can be hit or miss, even if you are patient.
Looks like the 42" is getting the nod so I'll keep an eye out.
Mind you, I'm shopping for a tractor that hasn't even arrived yet!! The Mahindra 3316 that I'm after has a SSQA loader but does this mounting system follow a standard dimension? In another words, can I get any brand of SSQA pallet fork?
   / Pallet fork size - 36", 42" or 48"? #50
No doubt... have you tried searchtempest? (or another compiled search).. it saves a ton of time :2cents:
MB
Massey Ferguson 9250 (A56436)
Massey Ferguson...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
NEW HOLLAND 648 ROUND BALER (A52708)
NEW HOLLAND 648...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
