Scooby074
Super Member
I'm not sure to whom those 2 thoughts are aimed at. Can you elaborate?
A general comment/question... not aimed at any one specific.
All of it.
How did any of us survive 12 years in a public school lighted entirely by florescent bulbs? Lots of people cover their garage ceilings with florescent lights too. Same difference.
The waste heat given off by any light bulb in Ohio is likely powered by a coal-burning power plant that spews mercury into the atmosphere. There is no free energy lunch.
It's too soon to tell if the led's will make their reported 20 year life. Led technology is rapidly closing the gap in price and quality compared to cfl's & I bet in 5 years almost all bulbs will be led's.
Yes, they are next to many cash registers at checkout for under $2 eh?
Dont forget those schools had lead paint too! A miracle any of us survived
I agree with your statement that any "heat" given off is offset by some spewing plant somewhere. If your heating your house with lightbulbs... you're doing it wrong:laughing:
Scoob:
I think you missed point almost entirely, what I was talking about is "Total Cost" for a bulb, that the cost of the CFL or LED vs Energy Saved and Energy to make, run and disposal costs overall. When do you use lights? (is when it is dark for 95% of the lights made, they are on when needed in the dark.)
So lets take a regular light inside someones home, they get up in AM and turn on the bathroom lights and bedroom lights. While getting ready for work or school these lights run maybe 30 min in the AM. Same for after work/school during the winter you get home and it gets dark at 4:30 so on come lights. These lights are now on from 5ish till 11pm say. The use of lights can now come into play for overall costs, LED vs CFL vs standard Incandescent bulbs. If you look at them in terms of cost to buy, LED $20 to $40 bucks, CFL $2 to $15bucks and the incandescent is .40cents to maybe a buck. So now for real world you have to figure electricity cost vs bulb cost and the expected life span. A bulb that has a high cycle rate vs time on rate will burn out sooner (hours of actual use) vs one that is on till it burns out 1000s of hours later. Conditions also comes into play one used in a dark cold damp spot vs a warm dry living room
also comes into play as to what bulb you should use.
This is where a LOT of different things needs to come into play, for example how many times a day it is turned ON/OFF or how long it is ON vs time OFF. How many times the bulb will last under these ON/OFF cycles and times. A bulb that is put ON in a commercial bathroom & stays on till it burns out vs a bulb in a home closet or basement or one outside that turns ON when someone walks by then goes out some time later.
A Bulb that is on 24/7/365 till it burns out is excellent candidate for LED or CFL where as a closet/basement bulb used maybe a few times a month then the incandescent is the way to go for best use of your purchasing dollar. This is the no nonsense easy to see because they are at the outside areas of the point of use graph you could draw. The real number crunching comes into play when the use (number of times turned on/off and when/where used) falls in this peak of a graph that cost to buy vs energy saved vs bulbs life or easy replacement really is the guts of what is better for every particular situation..
That is probably less than 1%, over regular light-bulbs that are momentary used inside a home/office. If there is a can fixture 30 feet in the air and difficult to get to then the 40buck high lumen LED would be the choice over a incandescent version.
On the regular incandescent bulbs which are not efficient at producing light but produce heat better. This added heat in winter is not wasted but is a gain to overall homes efficiency when total calculations are done. Remember that Electrical Heating is about the most efficient in heating applications as none of that goes up a chimney. So when you have a bulb say on the coffee table that is run 4 hours a night in winter or maybe 1hr in summer only when needed. The energy used in the 4 hours in winter is not quite the same VALUE in $ as one would might think. Lets look at a 100Watt incandescent light under these conditions. 100Watts = 1740 lumens and that is only ~2% efficient so 98 watts are given off as HEAT and 2% as lumens. This heat in winter can help out the heating side by that additional 98watts given off in the room. (FUNNY NOTE: I do heating systems for a living and had several calls to same place where lady kept saying the heat was very inconstant that it would get real cold in much of the house. When I went to take a look I found the issue, she had a side table with a lamp setting under the thermostat. She would set and read by the 3 way lamp which would keep the thermostat from coming on when room temps dropped. Showed her what was going on by having her hold her hand over the top of the shade to feel the warmth vs rest of the room.) She learned that having 100+ watts of heat under her thermostat caused the furnace to NOT run and home cooled off.
Our bathroom is only maybe 36 SF (270CF) but we have 200 watts of lights inside it. In the winter close the door and turn on the lights and it warms it up nicely after a few minutes, we dont have to be COLD climbing into the shower do to the heating from the lights. does that cost more $ vs using LEDs no not when you have a warm room![]()
Even CFLs are better at producing HEAT than LIGHT (CFL=45-75 lm/W) vs 12.5-17.5 lm/Watt from Incandescent.
There are a lot of items to consider when you decide to do a buildings load calculations for lighting/heating and the like so just to let you know what does go into these things.
Mark
My problem with all this has been in my area, I've never been able to find an LED light with acceptable light output. Those I've tried left me with a very dark room. Now, I live out in a retail black hole; 130+ miles to the nearest Home Depot, Lowes or other big box home improvement center. Our local shops have a very limited selection to choose from. This makes experimentation with LED's a very costly and time consuming process which I am just not willing to partake in on a regular basis. I just don't have the time and money to make multiple day-trips to franchiseville just to try a different light bulb in hopes of saving a few bucks. We have a few florescents in various forms scattered around the house along with a bunch of incandescents. Until I can find an LED (actually see it with my own eyes) that produces a bright, white light, as opposed to the dim, blue light I've experienced, I'm not likely to change anything soon.
Just my :2cents:.
Joe
As someone who lives near latitude 45 degrees, the heat by-product from any device is fine in winter, but not in summer.
Total costs need to include more than manufacturing, disposal and point-of-use. Reducing total energy consumption has a cost benefit of reducing pollution, the habitat impacts of mining, and carbon transfer from the burning of fossils fuels.
Due to more frequent and longer lasting warm spells, many people in this area are opting for air conditioning that they didn't need before. That is a cost to buy and operate that is directly attributed to a warming climate. Nobody really knows what the net costs of global warming will be, but they appear to be significant. The costs do not appear to be offset by coincidental benefits.
The cost of power generation, from any source solar to coal, and the cost to build capacity and operate the distribution grid also benefit from energy conservation. Whatever energy is conserved, the reduction of costs roll back into the infrastructure.
The major portion of home energy use for lighting is not the two minutes a closet light is on, or the 30 minutes in a bathroom. It's true there is not much to conserve there on an individual basis, multiplied by millions of closets though it adds up. The lights that are used all afternoon until bedtime do offer a larger chance to conserve. CFL and LED lights will make a ~66% reduction in energy consumption for those long usage lights. That is a significant amount of energy conservation that they make possible in each home.
I really don't think it is possible to defend incandescent bulbs from a true total cost or energy conservation perspective.
As to being forced to bring a toxic device into your home, whether or not your home is really non-toxic already, the risk is low and largely depends on your handling and care to see that they are properly disposed of. Proper disposal is difficult. I'm pretty sure when I return a CFL to the point of purchase, there is a good chance it gets put in the dumpster. I have no solution for that in a rural area with a sparse population, but I don't see how blaming the bulb really makes sense either.
If incandescent bulbs remained on the market, people would buy the lowest apparent cost bulb with the highest true costs. It's that simple really because they aren't directly paying those true costs--well they are but it's invisible; it's certainly not showing up in the comparative cost of the light bulbs. It's like shopping at stores that sell mostly imported products and wondering why no one has a decent job.
I think what is unfortunate is that it impossible to educate people in-depth on true costs, some of which aren't even easily quantifiable. It's also unfortunate we are losing our ability to identify and address commonly held goals with clear benefits. The more complex and challenging the needs become, the more it matters to be able to pull on the oars together, but it's also easier to gain or retain advantages by introducing confusion and distrust.
Just my perspective to what you were saying.
Yes the heat from bulbs is not good in summer, BUT you need lots less light in summer as the sun is out till way later in PM 8PM it still is light out, now it is dark at 5PM 3 hours less run time.
Summers have not been that much warmer the people are more conditioned to AC in work and home cars etc, it is actually not much difference in HEAT and on the last few years there has been only a few HOT spells while rest of the summers have been below average.
Power Generation (actual consumption of power) has been dropping by a large amount in US, there are a LOT less factories now than 15 years ago, we actually have an abundance of power for NORMAL use. They have been closing Coal power plants in last year by large numbers being replaced by small Nat Gas point of use type generators gone by the way side are the massive coal burning plants. The ones remaining are being powered at lower rates & are using cleaner technologies & lower sulfur coals. Wind and Solar plants are helping off set the De-commissioning of old coal plants & lower consumption devices are reducing actual used KWs. The only real issue is the PEAK demands during a few days per year when everyone thinks they HAVE to have AC on..
I agree there are people (I know a lot of them) that have nearly every light ON in the home this is a PERSONAL problem not a Government Energy Mandate Problem. If you drive by any of the HUD (Government Assisted Housing Complexes) there you will see lights burning everywhere with the people having doors windows and balconies open with the AC cranked... oh did I mention these places people pay small amount of rent and get Heat and Electricity for 25bucks per month regardless of what they use... (Ya dated a girl that lived in one, sure must be nice to only have to pay 25 bucks for heat, Lights AC etc...)
Edit in: FYI right now we have on 1 LED nightlight, one Florescent floor-desk type lamp and a fluorescent fish-tank light, along with the lap top & LED TV. This is where a great deal of LOWER energy consumption has happened in last 10 years. We switched from a BIG Floor model TV (TUBE) style and two desk tops with 19" Tube type Monitors to two lap tops. This probably cut our consumption by 40% as the old desk top tower style computer with a tube monitor used 1200+ watts and old style TV was probably 1000 watts. New TV is probably 300 Watts, the Lap tops are 120watts so with the NEW technology there is saving ~1780 watts which is multiplied across the USA which is where just updating old tech is better than all the Government Mandates which usually are behind the curve and cause more issues than they fix... Healthcare is a perfect example...
Mark
I will say that government mandates are an expression of leadership. Phasing out leaded gasoline is an example of something that would not have occurred without leadership expressed as a mandate. Granted, some mandates are better than others.[/QUOTE
yeah, and that Ethanol mandate was a really really really bad one.
Just my :2cents:.
Joe
That mandate would be gone if not for the corn belt special interests. But there is a larger point there too. A market was artificially created for ethanol and a lot of farming and chemistry was done, but ended up not a winner. If you never fail, you never tried is what business people say. I don't expect different rules to apply, or vastly different outcomes, for something just because it is public or private. They are both done by humans.
Preserving a clearly failing program is the real sin IMO.
