START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800??
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #41
Doubt Rotella is a "full" synthetic. Think it's very likely a hydrotreated oil, meaning they use hydrotreating to remove unsats and aromatics rather than solvent extraction. It does produce a very good oil, but is not a full synthetic.
I converted our old 240D Benz to synthetic when it had over 200k on it. No problems. Also converted a Gravely that was using some oil to synthetic (both Mobil 1). After the 2nd oil change on the Gravely it actually quit using oil.
Ralph
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #42
Ralph
You may doubt it but here are the FACTS: Shell Rotella® Products - Shell Rotella
Easily found on google....:confused3:
Your mileage may vary, standard internet abbreviation. At the risk of taking more flack, if you're speaking to a specific person or persons in a thread, I suggest either quoting what they said by hitting the reply w/quote button or just using their username for clarity.
If you're thanking me- great, I appreciate that. If someone else, that's fine too, since there are contributors here like sixdogs that offer a lot of good tips, and just about everyone knows more about Kubotas than I do. I'll stick with this thread for now, but if things continue to sidetrack I'll be gone....
In general a machine is better off with topped off fluids than low fluids, even if they aren't an exact match.
Yes, my reply was directed to you.
How do I check to see if coolant needs to be changed?
Also, best way to start and let the b7800 warm up? How many seconds do I hold the key in the
first position before engaging the starter on these cold days? I tried between 12-20 seconds and
I found the engine cranked with white smoke coming out. Had to engaged the started 2-3 times before
it turned over.
Once started how long do you let the engine idle before operation and at what speed?
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #44
it turned over.
Here is a site that has your owners manual, the 2nd from the top. Based on your questions, I suggest you print it and read it. Your questions are all answered starting at page 18
http://www.kubotabooks.com/AutoInde...s/&AutoIndex=9959a03ad8c5d8b86a6326a2472cbf4b
I need to clean the engine and engine compartment-very dirty. Any advise on what to look
out for when washing/any possible problems?
Do all 3 panels simply pull off?
Tom-Thanks for link. I find the wisdom and experience of owners very valuable. Appreciated the time
of those who are helping answer my questions.
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #47
No problem. The manual should explain things in sufficient detail so that you properly maintain your investment. Good luck.
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #48
So did I. Switched from mineral 15W40 Pemco Diesel Ultra into synthetic 15W40 ELF Performance Victory on my M9000 after engine rebuild (200 hours).
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #49
Here from their msds sheet.
CAS# CONCENTRATION INGREDIENTS
Mixture 100 %volume Synthetic Motor Oil
92062-09-4 65 - 74.99 %volume Hydrotreated Petroleum Slack Wax
64742-54-7 10 - 19.99 %volume Hydrotreated heavy paraffinic
distillate
Mixture 3 - 8.99 %volume Hydrocraked, hydroisomerized HVI
paraffinic oil
Proprietary 3 - 8.99 %volume Proprietary additives
64742-65-0 1 - 2.99 %volume Solvent dewaxed heavy paraffinic
http://www.rotella.com/products.php3#synthetic
Ralph
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #50
it turned over.
Get a hydrometer:Amazon.com: coolant hydrometer
It can test the content as to proper mixture. The # of years in the system determines when to drain/replace with new, due to overall breakdown. Usually 2 years and change out.
White smoke is generally not a good sign at start up.
2004 Range Rover HSE SUV (A48082)
2004 Range Rover...
2019 Chevrolet Malibu LT Sedan (A48082)
2019 Chevrolet...
Char-Griller BBQ PIT (A50860)
Char-Griller BBQ...
2008 FORD F-450 (A50854)
2008 FORD F-450...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2014 Ford C-Max Energi Hybrid Hatchback (A48082)
2014 Ford C-Max...
