Kubota 3940HST with BH90 hydrolic cupling leaking
   / Kubota 3940HST with BH90 hydrolic cupling leaking #1
gusman2
Member
STOW,MA
KUBOTA L3940HST BACKHOE
MY back hoe is not used often. I hitched it up to do a bit a digging and the male from tractor to Backhoe is leaking when connected and running the hoe. It runs the hoe but leaves a puddle after 5 minutes. It does not leak out at all driving or parked over night with hoe down. I called dealer and they said cupler was 56 for just the female side. Is there a gasket kit or other way to fix this. There is only 50 hours on back hoe and 660 on tractor 2008. I would think with it being stored inside it would not have this problem. Any help would be great. Thanks Mark.
   / Kubota 3940HST with BH90 hydrolic cupling leaking #2
I don't know of any gasket kit, usually you would just replace an end. However, I bet there is just some debris keeping it from sealing properly. If the couplers are standard ag, did you check the female side for debris? Has the coupler set properly seated? Have you tried disconnecting and reconnecting a few times? Is your fluid clean? If so, the coupler is in pure oil, no way they should fail.
   / Kubota 3940HST with BH90 hydrolic cupling leaking #3
Hydraulic leaks are always a problem and the female couplings are the largest reason for leaks second being swivels. There is an initial o-ring that might be the issue and well worth a try although it will need to be matched up as it is not normally listed separate.
   / Kubota 3940HST with BH90 hydrolic cupling leaking #4
Tractor Supply stores have a good selection of hydraulic hose couplers at reasonable prices. I got a replacement pair for one of the hoses for the loader on my L3830. Just have to pick the right one. I took my old one in to make sure.
Thanks will be looking this week at tractor supply
   / Kubota 3940HST with BH90 hydrolic cupling leaking #6
I have fixed many of these on my BX2230....You can get the O-rings at any Hardware store just take in the old one and match it up.
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
SAMSUNG REFRIGERATOR / FREEZER (A54757)
SAMSUNG...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Toro Z-Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2014 Toro Z-Master...
