What hydraulic oil to use in DK50SE HST?
   / What hydraulic oil to use in DK50SE HST? #11
you do know you can get your hydraulic hoses premade At surplus center at a good price right?
Surplus Center
Yes, but I had Tuesday off and wanted to get the hoses made up and back on the box blade that same day. NAPA sells really good hoses (10,000 PSI rated, which is way overkill for a compact tractor), but they are priced like gold.
Next time, I'll plan ahead a little. Plus, about 1 hour after NAPA got my hoses done, a friend told me about a nearby small shop that does good work and is way less expensive. Timing is everything.
   / What hydraulic oil to use in DK50SE HST? #13
Double check the part number... Napa oil Part number 85-405
If I remember correctly they have three different variations of tractor fluid.
   / What hydraulic oil to use in DK50SE HST? #14
Dealer sold me 40 litres@ $3/l. Roughly 10 gal. $120. TSC wanted $79 fr 5 gal premium oil.
   / What hydraulic oil to use in DK50SE HST? #15
Hmmmmmmmm ... TSC Web shows 5 Gallon Traveler Premium @ 39.99. Frankly, the dealer was selling Xtreme a few dollars cheaper but I consider it inferior to the TSC UTF.
   / What hydraulic oil to use in DK50SE HST? #16
Just looked, TSC has Unitrac @ $95 and Spirax @ $65, but you have to buy 2 or more to get that price. I'm in Canada and our TSC website is TSC Stores.
   / What hydraulic oil to use in DK50SE HST? #17
Where do you add hydraulic fluid to a Kioti NX4510 hst and what type of fulid should be used?
2015 Ford F-450 9ft Utility Flatbed Truck (A55852)
2015 Ford F-450...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
Case SV280B (A53317)
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
