Need to order Hydraulic Remote Kit for Kubota M9000
   / Need to order Hydraulic Remote Kit for Kubota M9000 #1
OKSTATE COWBOYS
Miami,OK
M9000 Kubota
Need to order remote kit for my M9000 2005 Kubota tractor. I have one remote and am wanting to put another one on the tractor. Where is the best place to order this? Do you just call it the remote kit? Do I need anything else? What is the anticipated cost?
Thanks,
TC
   / Need to order Hydraulic Remote Kit for Kubota M9000 #2
Do you want a factory kit or do it yourself kit?
What do you suggest? I'm open for anything. I was thinking about a factory kit but if there isn't any difference the other would work.
   / Need to order Hydraulic Remote Kit for Kubota M9000 #4
A do it yourself kit will be cheaper but won't fit as smoothly/easily. Do you anticipate requiring a "float position" on the added remote kit? It's my understanding that non of Kubota's 1st remote kit's have a "float position". I think a Kubota 2nd remote kit is in the $800-$900 range.
   / Need to order Hydraulic Remote Kit for Kubota M9000 #5
Here is a Surplus Center three spool stacked valve to get you stated.
$369.90
Add hoses, QD's, and mounting bracket.
   / Need to order Hydraulic Remote Kit for Kubota M9000 #6
You should call your dealer and get a price, then put it on yourself. There are a quick a few options for your tractor, also while your at it get a parts manual.
   / Need to order Hydraulic Remote Kit for Kubota M9000 #7
   / Need to order Hydraulic Remote Kit for Kubota M9000 #8
My suggestion is to get the OEM price for the 2nd rear remote. Then you will feel good about any of the ways that you can go with aftermarket stuff. I suggest a diverter setup and use the single OEM rear remote to feed those. Have done this many times and most everyone has been happy with the results. :thumbsup:
   / Need to order Hydraulic Remote Kit for Kubota M9000 #9
Why pay for something(parts manual) that's available online for free?
Yes Jim I know that, just if he got the manual he can see all the options there are about 5 or 6 for his tractor. He can do the search for it. I'm guessing the 2nd valve is around the $300 to 400 price.
   / Need to order Hydraulic Remote Kit for Kubota M9000 #10
I may be way off on pricing, only going by what my customers tell me, but once Kubota goes out of production on a model, the parts go up in cost and not just a little bit.
But this is hearsay and why I said to go and get the price for the OEM unit to start with. ;) I would be interested in hearing what Kubota actually wants for the 2nd valve for his tractor.
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
