advice on low flow attachment for kubota M59 front loader hydraulics
   / advice on low flow attachment for kubota M59 front loader hydraulics #1
kolbster
Picton, Ontario
2011 Kubota M59 w backhoe
I have a 2010 Kubota M59 with backhoe and am looking at getting some attachments given I have hydraulics to the front end loader. By the specs, the flow rate is 16.1. Any advice if I want to get
1) a rock grapple bucket
2) an auger
3) a front end brush cutter
   / advice on low flow attachment for kubota M59 front loader hydraulics #2
That rating is prolly at rated engine speed. with your grapple & auger you'll prolly be working with your foot throttle at low rpm's & you'll be fine. In skid steer language, that most of these attachments are made for, 16-20 gpm is "low flow". High flow SS's have upward of 30 gpm's.
   / advice on low flow attachment for kubota M59 front loader hydraulics #3
I think you'd have too low of flow for a brush cutter and also have a problem with the oil getting too hot for continuous operation.
   / advice on low flow attachment for kubota M59 front loader hydraulics #4
You can get a PTO driven pump to drive a rotary cutter, they are around $3k.
   / advice on low flow attachment for kubota M59 front loader hydraulics #5
Or use a standard brush cutter on the 3pt/pto. The 3 point setup is the biggest advantage an M59 has over a full size machine.
   / advice on low flow attachment for kubota M59 front loader hydraulics #6
The M59 can drive a front auger just fine; several of us on here have one. Just be sure you size the auger to the flow rate. The rated 16.1 is the maximum, but is probably not far off the mark for an auger which is not likely to be run continually. Front grapple is no problem at all of course since it does not care about the flow rate.
ATTACH=CONFIG]329458[/ATTACH]
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
