JD Gator with the best low-end pulling capability
   / JD Gator with the best low-end pulling capability #21
Buy a small 20-30 hp front end loader, you'll never look back!It will do everything but play in the woods, buy a used XUV for that. For the cost of a new Gator/Workman/Cushman etc... you can easily buy both a used FEL and XUV. You will be much happier I guarantee!
   / JD Gator with the best low-end pulling capability #22
unless your going to buy 1980's stuff with loads of hours, this is not true.
   / JD Gator with the best low-end pulling capability #23
I can buy a good working front end loader here from $4500-$6000 ALL DAY AND FOR $5000-$7000 ea I can buy enough XUV's to fill a large trailer. That totals $9500-$13000, how much is that new Gator?
   / JD Gator with the best low-end pulling capability #24
can I have some? typically even a 10-year old BX in average condition brings 7k+. A good loader tractor for 4500 is virtually unheard of. Maybe it depends what you consider "good".
   / JD Gator with the best low-end pulling capability #25
I'm not joking, there was a Kubota with 500 hrs, front loader, belly mower and rear blade for $5800 on Craigslist about a week ago and that is not uncommon.
   / JD Gator with the best low-end pulling capability #26
I see a lot of LOW priced LOW hour tractors on Craigslist............................SCAMS!!!!!!!!!!!!!!!
   / JD Gator with the best low-end pulling capability #27
Yep, And its getting worse lately.
   / JD Gator with the best low-end pulling capability #28
I know the ones, I ain't stupid, nor did I just fall off the turnip truck, The Kubota was a local tractor with a local phone number and pictures of the truck sitting beside it with local tags.
Those generic ads don't get a second look from me.
   / JD Gator with the best low-end pulling capability #29
I just looked and counted 7 within a hundred miles of here for under $9500, then I found 4 decent XUV's for under $5000-$6500, that still totals out to the cost of a new heavy duty Gator.
   / JD Gator with the best low-end pulling capability #30
Did mean to imply that. No offense meant
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
(10) 12" X 22# I BEAM (A57192)
(10) 12" X 22# I...
2019 Range Rover Super Sport AWD SUV (A55853)
2019 Range Rover...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
Striker TNB-4M (A53317)
Striker TNB-4M...
