lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 9,103
- Tractor
- Bobcat CT 235
I never get luckyI've been mostly lucky my whole life, so I'm not too concerned.![]()
:thumbdown:
There are probably many more 'normal' filters like the one I posted out there than the bad ones.
Is this normal? I sure hope not.
I've been changing oil/filters on trucks, cars, tractors, motorcycles, and whatever for 59 years and have never seen anything like that first photo in this thread. Oh, and some have been Chinese manufactured and none had anything even remotely close to that bunch of metal.
I would be raising **** at the dealer and at Kubota. I can't believe that some say that is OK.
I was a bit anxious also. Looks like all aren't as bad as the Op's...FWIW - Did the 50 hr this morning on my new l3800 and the magnet on the filter was almost clean as new.
After seeing the OPs filter I was a bit anxious to take a look at mine...
Ditto. Could not agree more!
And a question for the OP:
What if the bag you put the next filter in, for dealer inspection, unbeknownst to you, already had machining debris REMARKABLY-IDENTICAL to the original debris, in it? That could happen, because my favorite auto-supply store also has its' own, FULL-SERVICE machine shop out back. And they have these GREAT, plastic bags they use in the retail store--which I REUSE, as they're big, strong and leak-proof. So who's to say HOW that bag got contaminated? Could have come from an auto store like the one I'm describing.
And this new debris stuck to the magnetic ring, and even you didn't know it, until you pulled the filter out of the bag, to show the Regional Rep., the dealer, etc.... (Think about it--if Kubota can FAIL TO CLEAN OUT A TRACTOR, you could have failed to notice a contaminated, plastic bag, right?).
And maybe you didn't even notice the extra debris, until or when you handed it over?
And they said: "Okay...whellpp! There's more metal, so that's it-sign here-we'll give you a new tractor."
I mean, you wouldn't want to have wasted the Regional Reps time, right?
The polite thing to do would be to accept a new tractor, no?
Just wonderin'....
Cannot argue with you even a little bit!I will give a follow-up as soon as I change the oil again. It's been roughly 5 hours since I last changed the oil so if all goes well I will put the next 5 hrs on it this coming weekend.
CHILLY807--And since someone suggests he should "get the tractor replaced", what makes you think the next one will be any better?
I'm not really following you here nor was I following you when you said something to the effect of I are't to get rid of my tractor, i'm not going to be "satified" anymore. You have quite the negative attitude my friend or so I think. I am plenty old enough to make my own decision on what I want and don't want but thanks for your 2 cents. My L3200 does what I need it too, if it didn't I would have a New Holland, Deere, whatever you may have.........with that being said, ANYONE who pays $17,000 - $20,000 and changes the oil and has metal chips like I did, will wonder how much longer bearings/internals will last before they take a sh*t. Well let me back up and say anyone with half decent common sense would wonder. NO ONE said another tractor would be any better, but being a company the size of Kubota, it HAS TO BE a possible thought or option. Me reporting senarios like mine, might help them in producing a better cleaned, more complete unit. That is what companys strive for after all.
Chilly807 said:This is the post I was referring to, in fact. It's pretty obvious what the poster had in mind, and it pissed me off. The dealer's trying to help you out here, to the tune of free fluid and filters, telling you they will make it right if you have problems. I'm not employed by a dealer, Kubota or otherwise, and in fact Kubota has given me plenty of reason NOT to recommend an L series tractor.
My point is, we've seen almost no evidence of damage from metal contamination over the years, this problem isn't new by any means. I really doubt yours will ever give you problems stemming from this.
My negative attitude doesn't really matter much, but if this thread is any indication of your faith in your dealer or Kubota in general, you may be well served to simply request to return the tractor and get something else. I doubt they'd take it back now, but this episode will always be in the back of your mind. My thought is also that they could give you a second L3200 since this one was contaminated, and the second one will be no better. What then?
Speaking one's mind isn't always popular, but you did ask for opinions.
Kubota may have made some production line changes recently, if RailDawg and Bluegill's filters are any indication.
Sean
