Made a hydraulic top link extension
   / Made a hydraulic top link extension #21
Except in transport, the toplink deals mostly with compression force. However, if transporting a heavy rotary cutter, your comment is absolutely valid.
whether the top link is in compression or tension the load on the welds is the same - it's a shear load perpendicular to the weld group. since the load is centered about the weld group it doesn't really make much of a difference. there is a slight angular component to the load, since the top link isn't going to be dead perpendicular at all times, but asuming the load is perpendicular the 1/4" overlap isn't much of an issue.
if you had that same 5" long group of welds but the top link attached a few inches above the welds then the difference between the 1/4" overlap and 1" or 2" would become very significant, but as long as the load is centered about the welds then it isn't.
   / Made a hydraulic top link extension #22
you've altered you 3pt geometry by a fair amount by moving the pivot point back those inches. Has it caused any problems for you?
Not in the least bit. I wandered what it would do, but I can't seem to find any difference other than when the draft arms are all the way down, the top link doesn't hit the PTO shield now.
Thanks! That was a mouthful. :thumbsup:
2024 CATERPILLAR 305CR EXCAVATOR (A52707)
2024 CATERPILLAR...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2018 Kubota RTV 1120D (A56469)
2018 Kubota RTV...
(4) 10 LUG WHEELS (A57192)
(4) 10 LUG WHEELS...
TANK MANIFOLD (A58214)
