Made a hydraulic top link extension
   / Made a hydraulic top link extension #11
if you were asking me, the answer is not exactly...I get full motion of the 3ph no matter, however:
I have a hydraulic toplink and, yes, I move it in or out as required ...usually to get the implement up high for carry (perhaps that is what you meant?) ...other answer: it depends on the implement both my rotary and finish mowers, themselves, have swinging toplinks...on my rear blade, which does not usually come w. such, I use it to provide "compliance"...i.e., to accommodate the hydraulic tail wheel it has so I can separately adjust the angle of attack of the blade and it also allows the blade to kick up if/when it meets that old immovable object.
   / Made a hydraulic top link extension #12
I like the concept; but I'm concerned there isn't enough material overlap that the welds may fail.
Except in transport, the toplink deals mostly with compression force. However, if transporting a heavy rotary cutter, your comment is absolutely valid.
   / Made a hydraulic top link extension #13
Sorry I didn't say who my ? was for. It was for High Compression.
Joe yours wouldn't do what I was asking.
Very cleaver... :thumbsup: I like the design.
Thanks, but I can't take full credit. I got the idea from another TBN'r.
how long is the stroke on the toplink cylinder? I've got a 1 1/4"-10" cylinder kicking around and thinking about making a hyd toplink for my little Beaver....
Mine is a 15" stroke 3" bore. It's the Kubota top n tilt.
not sure if this would have helped but, when necessary, I lengthen my hydraulic top link at the other end with the HF "swinging toplink" ...as shown
No, that wouldn't help, because I need to be rigid. For example my box blade, If I want to make the bite less aggressive, I extend (push out) the top link.
Do you have to move the top link in or out to get full travel of the 3pt.?
The top link pivot should be in line with the lower link pivot.
I guess the Kubota Engineers didn't get the memo. Because the draft arm pivots are a good 8"-10" forward of the top link pivot on an L5740. But to answer you question, no. I have full range of motion regardless of top link length. :thumbsup:
Yes, you are absolutely correct. I should have been more clear. I assumed that they were worried about the tension loads vs. the compression loads.
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
(2) SPACE-RAY INFRARED HEATERS, INDUSTRIAL (A57192)
(2) SPACE-RAY...
2020 Hino 195 20ft. Electric Box Truck (A55852)
2020 Hino 195...
FUTURE FT-ZWB BACKHOE DIGGING ARM (A57192)
FUTURE FT-ZWB...
UNUSED FUTURE PAIR OF 7" MINI RUBBER TRACKS (A57193)
UNUSED FUTURE PAIR...
UNUSED 1RANCH 1RIG-13' 14' BI-PARTING IRON GATE (A57193)
UNUSED 1RANCH...
