Made a hydraulic top link extension
   / Made a hydraulic top link extension #1
High Compression
De Soto, KS
Kubota L5740-3/ Kubota ZD21 pro60
So I guess this is a common problem. I posted another blog for ideas for a solution. Thought I'd share what I ended up doing. Extended from center of pin to center of pin 4.125", which is how much my Pat's Easy Change lengthened my draft arms.
A little cutting with the plasma, drilling, welding and Voila!
A little Kubota grey paint.
   / Made a hydraulic top link extension #2
Looks like the rectangle tubing was perfect fit. :thumbsup:
   / Made a hydraulic top link extension #3
I like the concept; but I'm concerned there isn't enough material overlap that the welds may fail.
About a .125 gap left between the tube and the ears. So, pretty good fit. Not perfect, but it was what I had that fit the best.
Yeah... Pic isn't a very good angle. It does look shy. There is just a little more than .25" overlap. Agreed, not ideal, but all 4 welds are 5" long on .375" thick steel (which is the factory thickness). With the tensional load that is placed on the top link, I don't see them failing all at once. Since the lower draft arms carry all the weight, and the top link mainly stabilizes, I think it will be just at good as butt or tee welded joint. As long as I don't get carried away. We'll see. I'm not too proud to admit and show failure. As long as no one gets hurt, if anything breaks, I'll be sure to post it, so we all can learn from my mistake. :thumbsup:
   / Made a hydraulic top link extension #6
Very cleaver... :thumbsup: I like the design.
   / Made a hydraulic top link extension #7
how long is the stroke on the toplink cylinder? I've got a 1 1/4"-10" cylinder kicking around and thinking about making a hyd toplink for my little Beaver....
   / Made a hydraulic top link extension #8
Thanks for posting additional info on the steel thickness, weld length, etc.
   / Made a hydraulic top link extension #9
not sure if this would have helped but, when necessary, I lengthen my hydraulic top link at the other end with the HF "swinging toplink" ...as shown
   / Made a hydraulic top link extension #10
Do you have to move the top link in or out to get full travel of the 3pt.?
The top link pivot should be in line with the lower link pivot.
Kivel Quick Attach Hitch Plate (A56469)
Kivel Quick Attach...
UNUSED 1RANCH 1RIG-13' 14' BI-PARTING IRON GATE (A57193)
UNUSED 1RANCH...
UNUSED FUTURE X.PG44 44" HYD PLATE GRABBER (A57193)
UNUSED FUTURE...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A55315)
2017 Cadillac...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
