Snow I broke my new snowblower!
   / I broke my new snowblower! #1
149owner
MA
Cub Cadet 149, Kubota BX2200, LX3310, JD LX277
I got to use the snowblower yesterday for the first time and it worked great. I had put a piece of 1/16" stock under the blade and adjusted the skids to the ground. Today I went out to do a little clean up around the edges and snagged a corner of a tarp which then wrapped around the auger. I heard a big bang and then a lot of noise so shut it off as quick as I could. I figured I broke a shear pin so finished up with the plow. As I coming up the driveway I see a line of fluid in the snow so get out to see where it's coming from. I wasn't happy at what I saw! None of the shear pins had broken but the input shaft to the gear box broke and cracked open the case! Since this was only the second time I used the blower should this be under warranty?
   / I broke my new snowblower! #2
It shouldn't be breaking that easily. Strip the tarp out- take it in, say you hear a noise- no idea what happened, now it's broken. Want your money back or a new one.. Don't gp for repair because the casting could be bad on this entire machine. - Maybe just go for another brand or model. Could be a bad run. Don't say it was your fault. Nothing should break that easily.
   / I broke my new snowblower! #3
Who makes the blower?
   / I broke my new snowblower! #4
Obviously not a Kubota blower, some off brand per chance?
I'd take it back and play dumb (as suggested).
I suppose you didn't see the trap getting sucked up or you weren't watching??
Next time get an implement made better. That's a timy gearbox.
I have a Lucknow that I've run cinder blocks, tarps, fence posts and who knows what else through with nothing more than a slight jump (as the object comes out the chute).....
Saw 'em going in..... Saw 'em coming out......:laughing:
   / I broke my new snowblower! #5
Did you make sure your pto shaft was the correct length? A tarp shouldn't have done that kind of damage. I asked about the pto shaft because the dealer may ask you and try to say that the damage was done because it was incorrect. Just be thankful that it wasn't the rear of the tractor that broke. I have a friend with a BX who had that happen because the dealer who sold both to him didn't fit the blower to the tractor when he brought it down to them.
   / I broke my new snowblower! #6
Sorry to hear that happened....can only imagine how upset you must be. Being that it is a Pronovost, it is a high end piece of equipment, and not sure why the auger shear pin did not give way. My new Pronovost came with the wrong pins as I mentioned on your other post. I wonder if that happened with yours. Did you purchase it locally?
   / I broke my new snowblower! #7
I would second the suggestion of checking PTO length, it sure looks like there's more going on than just hitting a tarp. Is it possible that the tarp pulled the auger shaft out of the side bearing? Tarps and ropes can create some serious side directed forces when they wrap around a shaft.
   / I broke my new snowblower! #8
Your shear pins should have gone regardless of everything else. Unless you modified the unit it should be warrantied. I would not give the dealer any information you do not have to, just the it hung up on something and instead of shearing the pins the shaft went. Good luck!
I bought it last March after last years wild winter. At that time there were only two 54" Puma's left in the New England area. Unfortunately, the closest one was in New York state which is 3-4 hrs away from me. I'm calling the dealer today to see what he will do about it. I had called him about a month ago to get some shear pins and he was supposed to send them to me but I still haven't got them. I hope that isn't a sign of what is to come next!
   / I broke my new snowblower! #10
Another thing you can check out is to compare the gearbox description that is in the manual to the one on the unit. I noticed that mine is a different part number and is visibly a different one from another Puma size. Not sure if that is good or bad, but worth checking out.Good luck. Let us know how you make out.
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
BAT WING SHREDDER (A58214)
BAT WING SHREDDER...
MONTANA MOUNTAINEER 5TH WHEEL CAMPER (A52708)
MONTANA...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
