Rotary Cutter Shear Bolt and Slip Clutch
   / Shear Bolt and Slip Clutch #11
This is very similar to the slip clutch on my rototiller. The PTO shaft has splines and the bolt is used to keep the PTO shaft from slipping off the splines on the slip clutch. The nut came off the bolt and the bolt came out on my unit. Eventually the PTO shaft slid off the slip clutch splines. Fortunately I caught it in time to prevent any damage.
   / Shear Bolt and Slip Clutch #12
If the shaft is splined, it matters not where the bolt passes, it is NOT a shearbolt. The yoke can't rotate freely on the shaft if both are splined. :confused2::confused2:
Doh! So true.
   / Shear Bolt and Slip Clutch #13
If it were intended to be a shear pin, what holds the u-joint yoke on the shaft if the bolt shears. My Land Pride has a slip clutch but the book says on the shear bolt version there is a snap ring to hold the shaft in place in case the bolt shears. Think of it - with nothing to retain the spinning shaft, it could pull off the gearbox and you would have a PTO shaft whipping around in the air. Does the other side of the shaft, not shown in the picture, have a keyway? Not all gearbox input shafts are splined. It could be a shaft with key and cross bolt. My King Kutter RFM has a shear bolt but also has a snap ring to retain the shaft if the bolt shears.
   / Shear Bolt and Slip Clutch #14
I'm going to say that's a 'retainer' bolt also. Not a shear bolt.
   / Shear Bolt and Slip Clutch #15
If it's a splined shaft, definitely. Grade doesn't matter either. If it's a smooth shaft, it depends upon the grade of bolt. OR - perhaps a neglected slip clutch froze up on a smooth shaft, and the owner elected to put in a shear bolt rather than clean up the clutch.
//greg//
I will check to see if it is splined. Thanks for all the input!!!!
   / Shear Bolt and Slip Clutch #17
"splined",,,, I'm going to put my money on 'keyway'.
I think you are right!!!!!
I know the slip clutches are better, but I was hoping for a shear pin. It would have saved me messing with the slip clutch.
   / Shear Bolt and Slip Clutch #20
That might be what the original owner thought too.
//greg//
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2011 John Deere 7430 Premium (A53317)
2011 John Deere...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Massey Fergusson 4710 (A53317)
Massey Fergusson...
2015 Autocar Xpeditor T/A E-Z Pack 40 Yard Front Loader Garbage Truck (A55852)
2015 Autocar...
Wooden Swing Bench (A55853)
Wooden Swing Bench...
