NH 3010 Hydraulics
   / NH 3010 Hydraulics #11
Found it right where you said it would be. Thanks! My bolt has a little dipstick on it
   / NH 3010 Hydraulics #12
Thanks for sharing your info. I've been searching for the dipstick and fill bolt for my 3010 for a couple of days now! The owners manual clearly shows a dipstick and fill bolt near the PTO engage lever.
As for the difference between the 3010 and 3010S, Near as I can figure, the 3010 was made back before New Holland was bought out by Ford. When the company became Ford New Holland, they produced the 3010S, which was essentially the same tractor with just a little less hp. I think the dividing line is somewhere between '02 and '03.
Ford didn't buy New Holland. New Holland bought Ford in the early 90's, labeled the tractors Ford-New Holland til I believe '96 and then labeled them New Holland. Controlling interest in New Holland was bought by Fiat who then also bought controlling interst in Case International and is now called Case New Holland (CNH). At least that's the way I remember it. I believe it was still New Holland in 2002 and 2003.
   / NH 3010 Hydraulics #13
Thanks for setting the record straight. I'm not sure where I got my story but I read it (or something close to it) as I was researching a tractor I was wanting to buy. Just goes to show you can't believe everything you read on the Internet.
So, does anybody know the difference between a NH 3010 and a 3010S? There's not much info on these models out there.
   / NH 3010 Hydraulics #14
Go to tractordata.com and click on Ford-NewHolland. The 3010S is shown there. The 3010 is shown in the New Holland section. Apparently, the 3010 was made in Mexico and the 3010S manufacturing loacation is not indicated.
   / NH 3010 Hydraulics #15
i know the later S series were mexican made..
   / NH 3010 Hydraulics #17
i know my 7610s is mexican made.. anyway..
   / NH 3010 Hydraulics #18
the 3010 and the 3010s is the same tractor they are more of a econmy tractor run during the 30series tractor. If it is a 3010 it is a S series tractor made in mexico and after fiat bought out newholland and the 3010 is a fiat designed tractor never a ford design like the early newhollands where
newholland had to take of the ford name in 1996 and fiat bought out newholland in 1998 and case ih in 2000-2001
   / NH 3010 Hydraulics #19
Is there a way to operate a front loader on the 3010S without having to hold down the hydraulic lever? Also will the lift work independently of the hydraulics? Thanks.
   / NH 3010 Hydraulics #20
Does your machine not have detented remotes? If no detent, bunji the remote open that feeds your loader spool.
As to 3pt, did that machine have a 2 pump option?
3PT PEANUT WEEDER (A52708)
3PT PEANUT WEEDER...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56435)
2016 RAM 5500...
500BBL WHEELED...
2014 F-150 STX (A56435)
2014 F-150 STX...
2015 Ford F-750 Stellar 10628 10,000lb. Mechanics Crane Service Truck (A56858)
2015 Ford F-750...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3 Ton Crane Service Truck (A55973)
2017 Ford F-550...
